Is there any indication on how much of a performance increase this card will have on a 1080, fps wise ? Not bothered for benching and I don't plan on upgrading but just curious to see the performance gain from 1080 to the ti versions
Generally the NDA ends the launch day or maybe a day prior, so look to the 9th/10th for reviews and performance figures.When the reviews will show up? Do you think reviewers will get them earlier than 10th?
Is there any indication on how much of a performance increase this card will have on a 1080, fps wise ? Not bothered for benching and I don't plan on upgrading but just curious to see the performance gain from 1080 to the ti versions![]()
Should see nice performance at 4K with the extra memory bandwidth over the 1080, just what I need.
Is a 1080Ti worth it over a 1080 for 1440p? Generally?
pretty much this. And id expect the 1080ti to perform better so just use TitanXP as a baseline.Basically just see 1080 vs TitanXP reviews as that will be close enough.
You have a valid point, however, things need perspective. I play many games and frames are decent on my Gigabyte G1 1080 at 1440P but I still do get dips into 40s or even lower in some games (depending on settings of course). With a 1080Ti, it will allow me to have those extra settings and keep frames at a decent level. Not really a necessity but a nice thing to have. I also have a fund where I put money by from time to time to buy PC components and I work bloody hard for my money, so why shouldn't I or others buy what we like for our harmless enjoyment?
Wait... a 1080 can't handle 1440p at 60fps? Arer you sure? Cos by that, the 1080ti now looks much less impressive (and less capable of 4k60).
We wont have the magic 4k card until Volta Titan/Ti in 2018.
But by then there will be some other games that will punish enthusiast cards and bring them to their knees, no doubt about it!![]()
A 1080 can definitely handle 1440p@60. I've got dual 970s and the 1080 is faster than them (in most benchmarks). I've been running Witcher 3 and GTA V at 60 with max settings (except on W3 in some scenes where it's still very playable ~45). By my guess, the 1080ti will be capable of 4k60 at about the same level as the 1080 at 1440p (i.e. consistently). I suspect some of the less well-optimised games might force you to drop down a notch in graphics quality, though.
helloThere are loads of 1080 in MM already...![]()
Compared to my Zotac 980ti AMP Extreme what percentage speed wise will the improvement be? I'm at 2560 x 1600
