The real question is why did the Titan win any as they have the same number of cores but the 1080 Ti is clocked higher.
Interesting that the extra components fit into what were empty pads on the Titan. So they had these power enhancements in mind as part of the original design, but didn't include them on the Titan?
So if these go up at 6pm tonight, how much time do we have to buy them to get them delivered on Saturday?
Aquaero system. Not cheap but brilliant and modular controlling the fan as well as even flow rates, temps on everything in the PC and even water level in my reservoir. Will keep re using it.
What are you using to control your fan speeds Sorry, going a bit off-topic.
Aquaero dont have to have a front panel as they do an internal only controller which is solely software controlled. In fact after setting mine up initially I have never looked at the front panel once and its behind a door anyway.Just found it online. Damn that thing is...impressive. I'm tempted to find something that allows software control, as I like the front of my PC to be clean, and not have an LDC display on it. I will perhaps ask in the watercooling section.
Thanks
As for the 1080 Ti: Hope we get reviews soon! Can't take it any longer!
You can always add with pwm hubs anyway or have stuff connected the the pump or reservoir.This is what I use for all mine. Cheaper than the full unit and hides nicely away. Only shame is the single pwm which I use to control my 12 fans.
https://www.overclockers.co.uk/aqua-computer-aquaero-5-lt-usb-fan-controller-wc-011-aq.html
If they brought this one out when I was looking I'd have had this as it has 4 pwm outputs.
https://www.overclockers.co.uk/aqua-computer-aquaero-6-lt-usb-fan-controller-wc-31j-aq.html
Maybe someone wants to do a review thread? It will be handy to have all the reviews in one place but I ask whoever does it, lists all the reviews in the op please![]()
indeed lol![]()
Good manReview thread is open for business.![]()
Would love to know what are the bench results of 980TI vs 1080TI.
well, i stand corrected. out today instead of Tomorrow at 6pm as stated on Nvidia's hand out sheet.. haha, not that i'm complaining
sorry all, honestly Nvidia sheet I had stated tomorrow at 6pm lol
