For me it is i run **** at max ALWAYS !!! RIDE OR DIE !!! Even my LG G4 is running custom firmware and its overclocked.Its not worth it at above 4.0 the voltage required and the heat isn't worth the extra performance.
Out of interest what are you all doing with the Sata ports? I often don't use more than 3 and normally 2 these days.
Looks like am just going to have to go Asus X370 Pro....
abysmal launch is abysmal....
I use 4 myself. But if i had Raid ect deffo would use more. I use ********* of USB's oculus rift eats 5 itself !!!Out of interest what are you all doing with the Sata ports? I often don't use more than 3 and normally 2 these days.
Blue ray drive - 1
SSD - 1
General docs drive - 1
Media drive 1 - 1
Media drive 2 - 1
Backup drive - 1
So that's my 6 ports.
Although, to be fair, this Ryzen build is replacing my main PC for daily duties, so the media and backup drives most likely can go. However, when it comes time to replace that system, this system will drop down the chain, so will need at least as many sata ports as I need currently.
Not the worst choice, I got my 1700 with a prime x370 pro up and running today and have it running solid as a rock at 3.9 with 3k memory using DCOP profile overclocking method, was quick and easy. (0504 BIOS ofc)
I dont care about power consumption or heat. Just needs to be stable.
We are overclockers or pussies ??![]()
They are also on Finfet![]()
I hope the 5 and 3 series then clock better.
So I assume they will be limited to circa 4Ghz as well... doh.
If you're going 1.55 V full-throttle then maybe you'll have a better chance of getting acceptable temperatures on R3/R5 but other than that, no reason to think they'll clock higher.So I assume they will be limited to circa 4Ghz as well... doh.
TBF,if the leaked price of the 4C and 4C/8T ones is correct and SMT can get better scaling in games,I think fighting against a Core i3 and locked Core i5 CPUs,will actually be helpful for AMD.
