- 19 Jul 2016
- Mansfield
Never mind, I hadn't connected the 12v to the motherboard, doh!!! It also went in sleep mode after that but all working now.
PhewNever mind, I hadn't connected the 12v to the motherboard, doh!!! It also went in sleep mode after that but all working now.
Yeah it's a strange board for the price:/ It looks the best imo, but features comperable with board for a £100 lessToday I read a post on OCN that the MSI Titanium doesn't have BCLK adjustment. Not sure if user not seeing it, but not seen in manual/product page TBH. Fir the price it should.
I think he said about Infinity Fabric that connect 2 CCX between each other. It function on half of memory speed, so memory speed boost not only memory but total system.faster you run the ram the faster your system goes is a general rule anyway. But yes NB freq is 1:1 with RAM speed.
Send me your memory sticks and i will happly beat it, cant beat it with my 2x16GB.....I hereby challenge every Ryzen owner to beat my Cinebench score @4Ghz. Let's see what you've got gentlemen.
R7 1700 @4Ghz
3200MHZ CL14
1.350V
Score: 1770
EDIT got a slightly better score by 1 point with lower voltage now 1.350v. Not bad for a £320 CPU.
R7 1700 @4Ghz
3200MHZ CL14
1.350V
Score: 1770
R7 1700 @4Ghz
3200MHZ CL14
1.350V
Score: 1770
How have you connected your AIO to the motherboard? Are you using the AIO header on board or CPU header?I hereby challenge every Ryzen owner to beat my Cinebench score @4Ghz. Let's see what you've got gentlemen.
R7 1700 @4Ghz
3200MHZ CL14
1.350V
Score: 1770
its a crosshair. says in the picture.What mobo mate ?
R7 1700 @4Ghz
3200MHZ CL14
1.350V
Score: 1770
I hereby challenge you to run a thirty minute realbench stress for 16gb![]()
I'll give it a go, don't know if that is fully stable. Any particular settings needed?
Missed that....looks like the B350 chipset has issues...
Thanks for taking the time.
At the moment that is resulting in a black screen crash for me at stock on two different motherboards, different sets of ram, all when run at stock.
Like what? I did 3 hours of Encoding in Handbrake this time last week at 4ghz with my B350 motherboard and 1700, and finished another 4 and a half hours an hour ago (Although at 3.6ghz)
No probs, but what settings are you using? I've not ran that bench for a while.
