*** Official Ryzen Owners Thread ***
Today I read a post on OCN that the MSI Titanium doesn't have BCLK adjustment. Not sure if user not seeing it, but not seen in manual/product page TBH. Fir the price it should.
Yeah it's a strange board for the price:/ It looks the best imo, but features comperable with board for a £100 less
1700 @ Stock 70Watts pulled from the CPU
Boost clock @3.2Ghz over 16 threads.
3200MHZ CL13
1430 multi threaded
MT
1617 = @5960x @4Ghz with tuned DDR4 @CL15
1409 = @5960x @3.5Ghz with XMP DDR4 @CL16
For those interested, I have had reasonable results from the gigabyte ab350m gaming 3. Currently at 3.6 at stock volts and 8gb (2x4gb) ram running at 2933. Also the stock cooler is not so bad, currently at 70c under full load and reasonably quiet, but I will be needing something better if I am going to push this much higher.
Any suggestions for a quiet cooler?
I hereby challenge every Ryzen owner to beat my Cinebench score @4Ghz. Let's see what you've got gentlemen. :D
R7 1700 @4Ghz
3200MHZ CL14
1.350V
Score: 1770
EDIT got a slightly better score by 1 point with lower voltage now 1.350v. Not bad for a £320 CPU.
R7 1700 @4Ghz
3200MHZ CL14
1.350V
Score: 1770
Send me your memory sticks and i will happly beat it, cant beat it with my 2x16GB.....
R7 1700 @4Ghz
3200MHZ CL14
1.350V
Score: 1770
I hereby challenge you to run a thirty minute realbench stress for 16gb :)
R7 1700 @4Ghz
3200MHZ CL14
1.350V
Score: 1770
What mobo mate ?
R7 1700 @4Ghz
3200MHZ CL14
1.350V
Score: 1770
How have you connected your AIO to the motherboard? Are you using the AIO header on board or CPU header?
R7 1700 @4Ghz
3200MHZ CL14
1.350V
Score: 1770
Challenge accepted!!! But have to wait few days to receive my gear....... :)
I'll give it a go, don't know if that is fully stable. Any particular settings needed?
Thanks for taking the time.
At the moment that is resulting in a black screen crash for me at stock on two different motherboards, different sets of ram, all when run at stock.
No probs, but what settings are you using? I've not ran that bench for a while.
