Try just underclocking it, I don't think you answered before if it was factory overclocked?
So it's still unstable even with GPU underclock? did you do a fresh Windows install when you upgraded btw?
Man I neeed to stop typing these while testing as I never manage to finish before a crash.
So, I have done a total reset to stock - including removing all my upped voltages/power stuff.
While I was in there, I noticed the GPU was runnign at 8X - I know I saw it running at 16x before but can't remember when. So I re-seated.
restarted and fired up RB stress, and this time fiale dwith blue screen kmode_exception_not_handled with ntoskrnl.exe + nvlddmkm.sys flagged. Not sure if this is relevant to anything yet...
Ergh... So can't do this absolutely clean, as the stress test won't run without opencl installed.
Only way to install opencl is through installing the nvidia drivers.
So essentially, realbench offers you no clear way of testing individual items to gain a better idea of what may be the failure point.
There is a design flaw in Windows 10 Anniversary edition (1607) that causes black screens on certain setups, hopefully it's not affecting this platform too as it's actually the main reason I switched to Ryzen from X79Have you tried with NVidia drivers from a few months ago? if you can run Heaven and Prime95 then I find it hard to believe it's a hardware problem.
I'm running windows 10 home 1607 if thats of any helpThere is a design flaw in Windows 10 Anniversary edition (1607) that causes black screens on certain setups, hopefully it's not affecting this platform too as it's actually the main reason I switched to Ryzen from X79![]()
Would unigine Valley and prime be sufficient?
Though I suppose can just download heaven![]()
33 mins of realbench?Currently on 33 minutes.
Had a moment of anguish when I went in to see a black screen - thankfully it was just the screensaver!
Yeah. 16gb stress.33 mins of realbench?
