- 17 Sep 2006
- Gloucestershire
CH's bashing of the celebrities driving gets pretty old pretty quick! Clarkson just took the mick, but CH sounds genuinely condescending.
i was surprised to see them doing 80mph down a mountain with their engines off, that mountain must have been much steeper than it looked on TV
There was several cuts to keep the segment for each race concise - if you watched the entire 2+ minutes for each one it would make more sense.
While it was just a bit of fun I wonder if Harris, being the better driver of the two, struggled more with not being able to drive in the 'slow in, fast out' style that is usually quickest.The insurance for Matt must be hilariously high - Chris seems to do a good bit of his own driving though - might explain the big difference in the downhill times if Matt was swapped out for a professional driver but Chris did it himself.
If I had to try and find a fault then it would be that Rory would be more suited to the Gadget Show.
The Chris Harris lambasting of the celebs is a little bit cringe-worthy though.
