- 23 Mar 2011
Orzly tempered glass.
Thanks! I went ahead and ordered a pair of these! They sound easier to apply that the usual type?
Need a pouch or something now and I'm set
Has anyone tried a USB C to HDMI converter? I'm tempted to pick one up and keep that in the carry case as playing at work on a monitor would be perfect.
I'm pretty sure this has been tried and won't work, only way to output to TV is via the dock.
So far she's done 82. The fabric should arrive today and I have had to give her the day off work to get this all done!! Thank you to everyone, she's made up and says she will buy a new freezer with the money hehe. We will see![]()
I'm very happy with the protector that has come with the official case. Don't see me needing to change it over for a while.
What we need is to be able to buy a stand alone dock.
edit - which apparently is a thing and I didn't know that. $90 but no longer available on the Nintendo store.
That one can apparently lift with the heat of the switch in docked mode which the glass ones won't do.
I have had no problems with the Nintendo one either and will only swap to the Orzly if it does lift.
My has lifted but I think its because I put it on and then immediate put it in the dock to play and didn't let it rest.
And moving the sticks around causes the joycons to slide a tiny bit up and down and it does my head in.
That doesn't sound right, I have a very vey slight wobble in my left joycon when connected to the switch but only when testing it for movement, in use it's rock solid and in both the tablet and controller dock it's rock solid using the sticks no slide at all.
