Ryzen review:
Some quite interesting results for gaming while streaming too.
Very interesting was looking for something like this as I plan to record or stream
Ryzen review:
Well they will...in any game that doesn't use 5+ threads. I think the R3 will be a fantastic budget option, similar to the Pentium G4560, but going forward 6c-8c is where it's at. Of course, with AM4 you at least have an upgrade route: R3/R5 now, R7 in 1-2 years for minimal outlay. Personally I prefer to just go big and have the system last longer but I know some people sell and buy every year.
If you could let me know for sure once you've built it, that'd be great![]()
I don't trust the Steam survey for CPU core data as I imagine it's skewed by the large number of dual core laptops floating around not being used for 'proper' gaming. If you could extract only the machines with a half-decent discrete GPU I imagine the dual cores would largely go away (apart from some overclocked Pentiums I suppose).
Ryzen review:
Can I ask what is so wrong with the Prime X370 Pro? It seems pretty decent from what I have checked out.
Sweet jesus look at the size of that "case"!
Yes but the one without the glass sides, at half the priceLooks like it might be a Core P5 case
https://www.overclockers.co.uk/ther...se-black-tempered-glass-window-ca-18t-tt.html
Actually is the small 3 pieces that add the value. The case comes with the centred big piece of glassIts even cheaper than that - most retailers have it at £110ish. I didn't realise the glass used was worth £140!!![]()
That's no case.
It's too big to be a case
I have a really bad feeling about this.
