It will come back to you after about 4 restarts....
Thanks, tried that but still won't post and gets stuck on f9.
Think it's dead. Can't believe the crosshair doesn't have dual bios for the price they are.
Think it's dead. Can't believe the crosshair doesn't have dual bios for the price they are.![]()
Why all this downclock talk is this overclockers or power savers... This forum is getting sooooooo weak. 1 more Mhz not a 1000 less watts is the correct attitude!!
I had one of my BAD days. Fak energy saving bet u mised my post that other week i forgotten to turn my electric grill off after making 5% fat burgers. It was running overnight like 7-8 hours that thing is 2.5kw soI know one thing. My oven is 100% stable
With all this benching messing around im spending extra hours on my bodyweight trainign cause Benching when Benching so back below 10% body fat HAHA.
Back on topic. I applied Liquid metal on my cpu and while at it added 2 3mm leds that came in today. Looks not bad but cant see it anyway cause got no window in my side panel HAHA
Flashed 1001 bios now cant boot at 3002 but stable at 2702 by looks of it with 13/14/14 timings getting around same score in CB with those settings. Ill leave it overnight on torture test to fry things up a bit
Spends 800 quid on sidegrade wants to save on power bill BUHAHAHAHA. At lest my pc keeps me warm while gaming / testing stuff![]()
I give up. As I was playing the system shut down for no reason, temps were 40C. And since the return the number 8 error. bios reset does nothing nor flashing bios to any of the three versions (0902,1101,0038)
I haven't overclocked the system and wouldn't planning to do so until I had few days stable system.
however clearly I do not and have tried everything. Even rebuilding it again for second time today.
first time in 22 year and having build dozens of my pcs and hundreds for clients. Never had such issues having used AMD, Intel and Cytrix succesfully over the period.
I will call ocuk in the morning to return the 1700X and the motherboard. Maybe in few months things will be better but I want a working pc today not in 6 months.
It is very unusual how 50% of folk have a stable running system and 50% don't. It a very mixed bag! Hopefully this issues can be ironed out. I have not had one single issue since day dot, touch wood.
No worries mate.Sorry to hear dude, no problems here with this board using the latest 1001 bios.
I get the 8 error code right after the system has crashed due to the CPU not having enough Vcore.
Played around with 1001 bios and with my memory 0038 is just better. As i can work with 2666 instead od 2400. ATM stability testing 13/14/14//15/35@3001
While testing stability found on my backup drive old CB with my scores since 1090t times !!!
Not seen anythign liek here posted so there ya goHow my IPC went up over eyars.. O WAIT nope
no saved score but max tuned samsung green memory score was 2.02@5002 if i remember
No worries mate.
I unplug all USBs this morning, reflashed bios. Nothing.
Unplug the power, removed the graphic card, removed the battery for few minutes just in case is the CMOS. Nada.
Unfortunately idk what else to try
Could it be the mobo doesn't like the 1700X and works fine with all the 1700s?
Could be anything.
Little bit of a ghetto mod to get the GPU AIO rads in the left door as the pipes are to short to mount on the right and I have a 360mm CPU rad at the top.
All in all very pleased with the Ryzen 1800x. 63c max temps when full blown stress testing the CPU but it usually hovers below 56c.
I haven't seen XFR hit 4.1Ghz many times other than with the new HWinfo for a split second or so. Most of the time the CPU sits at 3.7Ghz on all cores with voltages ranging between 1.306v-1.56v
Currently running Corsair 2x16GB 3200mhz sticks at 2666mhz and will try the new Crosshair VI Hero bioses soon.
Vs my 3930K I get around 15% more FPS but the gameplay is a smooth as butter.
Im running everything stock but of what I have read online that only happens on XFR boost to 4.11.56V???
A bit high no?
Asus Crosshair VI Hero.Which motherboard are you running? Just out of curiosity.
Thanks!Stunning looking bit of kit indeed. Enjoy.
