How do you know what chips your sticks are usingMy CMK16GX4M2B3200C16 2x8GB Corsair sticks (Hynix) are running fine on my C6H @ 3200 with stock timings, BIOS 1001, +0.1 DRAM Offset.
temps sitting around 20 degrees idle / 35 degrees with p95 running
Hi everyone! I am new on Overclockers forum, but was following different release threads for sometime.
I have ordered my component from OcUK previously and now have received 1800x AMD Ryzen, Asus C6H and Corsair 32GB 3000MHz Memory kits 2x16GB on the 15th of March. The only thing is left is AM4 bracket from Corsair for my Corsair H105. Just wanted to say thank you to OcUK customer support for giving an updates about my order! Following this thread and other forums, I have realized that AMD does not support memory with 3000Mhz and 3400Mhz speeds. In theory I should be able to set the speed to 2666MHz and it will be fine, but wanted to confirm that this will work with you guys.
Mine must be one of the few using micron chipsAIDA64 system report.
Thank you for your reply badgeruk, I am fine with BIOS, but not very good with hardware installation due to a weakness in my right hand and have to ask a local PC service shop to install hardware for me. I will have to decide what to do this week, because I can return this memory kit as unwanted and be on a safe side or wait until bracket arrives and upgrade hardware. I am a bit confused with 3000MHz and 3400MHz because AMD announced that they are working on 2933MHz speed support but recommend 2666MHz and 3200MHz, hopefully it is just a matter of BIOS updates.You should be fine at 2666. Would be unlucky if you couldn't run at that but its worth trying a higher speed just to see if it works if you are happy with clearing the bios if it doesn't post. Also make sure you update to the latest bios.
That is the thing, I would not worry if I was upgrading to 8GB/16GB, but 32GB memory kits support is not so clear.I can boot at 2933 with 3000mhz sticks with the same board. I'm using 2x8gb so yours may differ. Bios updates improve things all the time though.
My gSkills didn'tI'm sure in time you will manage 16gb at 2933/3000.
Or in the mean time Gskill kits seem to have the best compatibility.
What board?My gSkills didn't
C6HWhat board?
This can't be right![]()
Thats what I thought but it does appear to be right, Ryzen master lists the temperature and the cpu cooler is not hot to touch (about as technical as you can get lol) My previous cpu would have been up over 70 degrees with this workload (FX8350)
http://imgur.com/a/nmWvV - theres some images of my temp testing
