- 7 Dec 2008
- Near Penrith on a farm
Thanks very much smokedog
Has anyone heard owt from samsung direct yet? - I placed my pre-order back in March, but order is still showing as "NOT PROCESSED".
Yes, using code: SAMSUNGSAVE30
But you have to use this link for it to work
https://eu.my-samsung.com/optiext/optiextension.dll?ID=SopSj43AbECmrDcPplEmh47FAt8XFq4Otxr0R4U+hUtlMIU8KZK0hB5sg9CqpfyvdkmqtiafwpqU0bNnbSFQ4bDSG308n
Also used Quidco for £13 cashback.
Just tried it and it worked for meUnfortunatly it doesn't work with the S8+![]()
Anybody got any thoughts on Samsung's 24 month price plan with the option to a free upgrade in a years time to the latest model after you've sent your 2017 S8/S8+ back?
Bought one from the rainforest last weekIs anyone going for a clear case? If so, which one?
I currently have an S6 edge that has always been in a Ringke Slim clear case which I found to be much better than Samsung's clear case. It is extremely slim but feels solid and protected the screen and body perfectly for the 3-4 times I dropped the phone in the last two years. I've just pre-ordered an S8 and searched for but couldn't find a Ringke Slim clear case for it listed as of yet.
Whats everyone doing as far as screen protectors goes ? This will be my first phone with curved edges and i've heard that the tempered glass ones are pretty crap
They're not cheap though, the spigen I've got for note4 is excellent and good build quality but makes it a bit too bulky, need something slimmer
