Caporegime
- 18 Oct 2002
Can someone please share their option in nvidia panel? Should the global vertical sync be on?
I ran mine with Gsync and Vsync on, was flawless
Fast Sync is unrelated to G-SYNC, but they work together to provide the best gaming experience. Fast Sync should be enabled when games have very fast render rates relative to the refresh rate of your monitor. G-SYNC is most effective when the render rate of a game is variable, and below the max refresh rate of your monitor. So both technologies can be active at the same time to deal with variable game frame rate scenarios.
I'm extremely happy with mine..out of the box the A04 versions are definitely tweaked better than the A03. I got my A04 from overclockers about a month ago so you'll get one an A04 rev. You won't regret it.Looking to pull the trigger on this today. Is there anything better for £500 notes?
lol do the whores have g-sync?
Cheers dude. I've had a tempirary block enforced by the wife but should be getting one soon..........
G Sync doesn't seem to work in Windowed mode?
Had to disable, enable, restart etc...Did you enable G Sync for windowed and full screen mode ?
Just setup one of these, unfortunately 3 dead pixels sigh, gamma was awful but intended to calibrate it anyway. Calibrated it with a display munki and to be honest the colour is actually really nice and doesn't look bad at all, but it goes down hill from there for me. Can notice the usual tn colour and contrast shift even when head on, and checking the lagom black level the shades of black go from dark blue to orangey/greenish tints, yuck. Would keep it still if it wasn't for the dead pixels but wont try another.
I'll keep the profile if anyone interested in using it, used a Colour munki Display. Revision was A04 and bought from the place that goes with naan bread
Black is black on mine :s though I have to compromise with a tiny little bit of black crush to get the most acceptable overall picture quality. I find having a bias strip on the back (only really works if you have the right coloured plain wall at the right distance behind it) really helps to increase the perceived image quality as well.
