Just got my system put together but I'm having issues, which it appears a couple of others are having over on the official forum. There appears to be some sort of compatibility issue with the X370 Taichi and crucial bx100 SSDs
My spec as follows;
Asrock X370 Taichi - BIOS V. 2.0
Ryzen R5 1600x
16Gb (2 x 8gb) Team Group DDR4 3200Mhz CL16
Crucial BX100 250Gb SSD
GTX 970 4gb GPU
Thats all that is currently connected to the system.
The drive showed up on first boot in the BIOS. Went to exit BIOS to tell the system to boot off my USB drive to install windows, the system reboots loads up the windows installer, which then says there isn't a HDD to install to.
So I go back into the BIOS and the BX100 has dissapeared. No amount of restarts would make it show up again. I tried loading defaults still nothing.
The only way I can get it to show up again is to shut the system down, remove power for 10 seconds, reset cmos and reconnect power and start it up again. If I go into the BIOS the drive is there again
There is no way I can install windows on this system with this drive.
Well, that's oddly specific. I've got a BX100 so I'll have to wait until that gets fixed before I can upgrade.
Wondering if any of you guys can advise. I have a TaiChi on order, wanted to know if
The RGB on the Trident Z RGB can be controlled with the motherboard
and
anyone with any experience of this memory with this board -16GB (2x8GB) DDR4 3600Mhz G-Skill Trident Z RGB - F4-3600C17D-16GTZR
Thanks for your time![]()
@AsrockMB can you confirm if the X370 killer sli/AC will be made available in Europe, or is it just a US thing? I can't see it listed anywhere...
Yes, you can controll the RGB with the g.skill tool - G.SKILL Trident Z RGB beta - download from their website.
I have got the lesser model RAM - 16GB (2x8GB) DDR4 3200Mhz G-Skill Trident Z RGB - F4-3200C16D-16GTZR
Was able to run it at just 2933 c16, altought listed as supported at 3200 -taichi mobo 1.94 bios - bclk 100.
Not sure if my memory is B.die samsung, but your model probably is so you should do 3200 with no probs.
Thanks for the feedback on the BX100, @ljt - we've reported that onwards. It does indeed sound like an issue with the AMD controller, but should be solvable with new code incorporated into a BIOS if it works on another controller such as the ASMedia one.
Had some of our techies look at it, and it's the first they heard of it. Checked with Crucial, who recommend a firmware update: http://www.crucial.com/usa/en/support-ssd?cm_re=us-support-_-main-_-firmware-update-linkNo problem, Thanks for forwarding it on. I've also posted it in the thread over on your official forums where there are a few others with the similar issues - http://forum.asrock.com/forum_posts...25463&title=x370-taichi-sata-ssd-goes-missing
It looks as though it's to do with the SSD controller used (in this case the Silicon Motion) rather than one specific SSD.
Let us know if this helps.
