*** Official Ryzen Owners Thread ***
Permabanned
15 Oct 2011
Nottingham Carlton
Ah ok, and is there a default setting or does every process need setting up? First I've heard of this.
I dont do default. U think why it took me 12 hours to install system :D
Like i said this is for power users that like messing about with EVERYTHING
Basic is free. Premium wel depends if u are a limewire Pirate ;)
2 Nov 2009
Brum
So just complete my ryzen build! after a few horror stories on mobos and ram i was expecting a nightmare... BUT, literally, put everything together, Installed windows, updated the bios. Not a single issue...
The CPU temp does weird me out a little being 48/50 deg idle... but i trusting this is this 20% offset.
This is the Gigabyte AX-370 gaming 5
corsair vengeance
1080ti
That sounds promising.
Can you please confirm the exact RAM that you are using, is it CMK16GX4M2B3200C16, and is it actually running at 3200 Mhz ?
Which CPU are you using, and have you overclocked it ?
This might be the upgrade that I choose (with a R5 1600).
20 Apr 2004
London
The ram im using is. CMK16GX4M2B3200C16. Check screenshot. Also states same on the motherboard bios. Any other tests?
2 Nov 2009
Brum
Looks good. Some people have no issue hitting 3200, others are stuck at 2666 using the same hardware. I think the IMC is to blame for this. Hopefully the May update can help a lot of people out.
I thought the MB and it's BIOS was the main factor when it comes to memory speed/compatibility. It still seems to be a bit of a lottery, and the hope that BIOS updates will sort any disappointed customers.
29 Jan 2015
West Midlands
Gupsterg a user on here and OCN had same memory kit same motherboard and x2 1700's 1 could do 2933 the other could do 3200.
Plenty of users on the same bios same ram kit are getting mixed results.
6 Jan 2011
bristol
Ram seems to be making a huge difference with ryzen, my 1700 could hit 4GHZ easy with kingston fury 2400 but with corsair vengeance led 3200 it runs full speed but can't get over 3.8ghz with the cpu
18 Apr 2017
Same RAM for me, although I have 32GB installed and so far it will only reach 2933Mhz, which it runs fine at. I'm not sure whether or not this is going to be the limit for four sticks of this particular RAM, as sure, I have seen people hit 3200mhz with two sticks but so far haven't come across anyone posting a 3200mhz result for 32gb of Corsair LPX. Perhaps, because it's apparently Hynix, not Samsung, that is its limit for that capacity (on the CH6).
BCLK settings up to 140 have not helped but I haven't tried really, really loose timings yet (how loose is loose though, I tried around 25 25....?!)
Perhaps then, this much of this particular RAM will have to wait on the next AGESA...
Caporegime
12 Jul 2007
United Kingdom
You'll need to increase either or both, CPUSOC and DRAM. For example, i could not get 4.1Ghz stable without setting DRAM to 1.5v, CPUSOC made little difference in my scenario, but your mileage may vary.
6 Jan 2011
bristol
my problem at the mo is finding time to play about with it but im happy enough at 3.8 and ram at 3200 to tide me over
2 Jun 2003
Bristol UK
Just got round to uploading images - I am now part of the Ryzen owners club! I have it clocked to 3.9 @1.35v at the moment, not pushed it any further yet. Probably going to replace the RAM with the Trident Z RGB on payday and send the Ripjaws V kit back as it can only run at 2133MHz, anything else and it won't boot. I know some of that is immaturity of the platform but the RGB stuff is at least QVL'd. Feels so snappy in the OS and it's like i'm playing games for the first time again, lovely stuff.
1700 @ 3.9
GTX 1080 FTW
16Gb Ripjaws V
5 Sep 2011
Surrey
Higher memory clocks increase the L2 interaction which makes life harder for the CPU, you should be able to dial the instability out, though
29 Jan 2015
West Midlands
Code:
[2017/04/24 15:00:48]
Ai Overclock Tuner [Manual]
BCLK Frequency [100.0000]
BCLK_Divider [Auto]
Custom CPU Core Ratio [Auto]
> CPU Core Ratio [38.00]
Performance Bias [CB15]
Memory Frequency [DDR4-3200MHz]
Core Performance Boost [Auto]
SMT Mode [Auto]
EPU Power Saving Mode [Disabled]
TPU [Keep Current Settings]
CPU Core Voltage [Manual mode]
- CPU Core Voltage Override [1.38125]
CPU SOC Voltage [Auto]
DRAM Voltage [1.40000]
1.8V PLL Voltage [Auto]
1.05V SB Voltage [Auto]
Target TDP [Auto]
TRC_EOM [Auto]
TRTP_EOM [Auto]
TRRS_S_EOM [Auto]
TRRS_L_EOM [Auto]
TWTR_EOM [Auto]
TWTR_L_EOM [Auto]
TWCL_EOM [Auto]
TWR_EOM [Auto]
TFAW_EOM [Auto]
TRCT_EOM [Auto]
TREFI_EOM [Auto]
TRDRD_DD_EOM [Auto]
TRDRD_SD_EOM [Auto]
TRDRD_SC_EOM [Auto]
TRDRD_SCDLR_EOM [Auto]
TRDRD_SCL_EOM [Auto]
TWRWR_DD_EOM [Auto]
TWRWR_SD_EOM [Auto]
TWRWR_SC_EOM [Auto]
TWRWR_SCDLR_EOM [Auto]
TWRWR_SCL_EOM [Auto]
TWRRD_EOM [Auto]
TRDWR_EOM [Auto]
TWRRD_SCDLR_EOM [Auto]
DRAM CAS# Latency [16]
DRAM RAS# to CAS# Read Delay [18]
DRAM RAS# to CAS# Write Delay [18]
DRAM RAS# PRE Time [18]
DRAM RAS# ACT Time [36]
VTTDDR Voltage [0.70620]
VPP_MEM Voltage [Auto]
DRAM CTRL REF Voltage on CHA [Auto]
DRAM CTRL REF Voltage on CHB [Auto]
VDDP Voltage [Auto]
VDDP Standby Voltage [Auto]
1.8V Standby Voltage [Auto]
CPU 3.3v AUX [Auto]
2.5V SB Voltage [Auto]
DRAM R1 Tune [Auto]
DRAM R2 Tune [Auto]
DRAM R3 Tune [Auto]
DRAM R4 Tune [Auto]
PCIE Tune R1 [Auto]
PCIE Tune R2 [Auto]
PCIE Tune R3 [Auto]
PLL Tune R1 [Auto]
PLL reference voltage [Auto]
T Offset [Auto]
Sense MI Skew [Auto]
Sense MI Offset [Auto]
Promontory presence [Auto]
Clock Amplitude [Auto]
CPU Load-line Calibration [Auto]
CPU Current Capability [Auto]
CPU VRM Switching Frequency [Auto]
VRM Spread Spectrum [Auto]
CPU Power Duty Control [T.Probe]
CPU Power Phase Control [Optimized]
CPU Power Thermal Control [120]
VDDSOC Load-line Calibration [Auto]
VDDSOC Current Capability [Auto]
VDDSOC Switching Frequency [Auto]
VDDSOC Phase Control [Auto]
DRAM Current Capability [100%]
DRAM Power Phase Control [Optimized]
DRAM Switching Frequency [Auto]
DRAM VBoot Voltage [1.40000]
Security Device Support [Enable]
TPM Device Selection [Discrete TPM]
Erase fTPM NV for factory reset [Enabled]
PSS Support [Enabled]
NX Mode [Enabled]
SVM Mode [Disabled]
SATA Port Enable [Enabled]
PT XHCI GEN1 [Auto]
PT XHCI GEN2 [Auto]
Onboard PCIE LAN PXE ROM [Enabled]
AMD CRB EHCI Debug port switch [Disabled]
Onboard LED [Enabled]
Hyper kit Mode [Disabled]
SATA Mode [AHCI]
SMART Self Test [Enabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
ErP Ready [Disabled]
Restore On AC Power Loss [Power Off]
Power On By PCI-E/PCI [Disabled]
Power On By RTC [Disabled]
Super I/O Clock Skew [Auto]
HD Audio Controller [Enabled]
PCIEX4_3 Bandwidth [Auto]
PCIEX16_1 Mode [Auto]
PCIEX8_2 Mode [Auto]
PCIEX4_3 Mode [Auto]
M.2 Link Mode [Auto]
SB Link Mode [Auto]
Asmedia USB 3.1 Controller [Enabled]
RGB LED lighting [Enabled]
In sleep, hibernate and soft off states [On]
Intel LAN Controller [Enabled]
Intel LAN OPROM [Disabled]
USB Type C Power Switch for USB3.1_E1 [Auto]
USB Type C Power Switch for USB3.1_EC2 [Auto]
Network Stack [Disabled]
Debug Port Table [Disabled]
Debug Port Table 2 [Disabled]
Device [Samsung SSD 850 EVO 250GB]
Legacy USB Support [Enabled]
XHCI Hand-off [Enabled]
USB Mass Storage Driver Support [Enabled]
Lexar USB Flash Drive 8.07 [Auto]
USB3.1_E1 [Auto]
USB3_1 [Enabled]
USB3_2 [Enabled]
USB3_3 [Enabled]
USB3_4 [Enabled]
USB3_5 [Auto]
USB3_6 [Auto]
USB3_7 [Auto]
USB3_8 [Auto]
USB3_9 [Auto]
USB3_10 [Auto]
USB2_11 [Auto]
USB2_12 [Auto]
USB2_13 [Auto]
USB2_14 [Auto]
USB_15 [Auto]
USB_16 [Auto]
CPU Temperature [Monitor]
MotherBoard Temperature [Monitor]
VRM Temperature [Monitor]
PCH Temperature [Monitor]
T_Sensor1 Temperature [Monitor]
CPU Fan Speed [Ignore]
Chassis Fan 1 Speed [Monitor]
Chassis Fan 2 Speed [Monitor]
Chassis Fan 3 Speed [Monitor]
W_PUMP+ Speed [Monitor]
CPU Optional Fan Speed [Monitor]
AIO_PUMP Speed [Monitor]
W_FLOW Speed [Monitor]
W_IN Temperature [Monitor]
W_OUT Temperature [Monitor]
CPU Core Voltage [Monitor]
3.3V Voltage [Monitor]
5V Voltage [Monitor]
12V Voltage [Monitor]
CPU Q-Fan Control [Disabled]
AIO_PUMP/W_PUMP+ Control [Disabled]
Chassis Fan 1 Q-Fan Control [Auto]
Chassis Fan 1 Q-Fan Source [CPU]
Chassis Fan 1 Smoothing Up/Down Time [0 sec]
Chassis Fan 1 Speed Low Limit [200 RPM]
Chassis Fan 1 Profile [Standard]
Chassis Fan 2 Q-Fan Control [Auto]
Chassis Fan 2 Q-Fan Source [CPU]
Chassis Fan 2 Smoothing Up/Down Time [0 sec]
Chassis Fan 2 Speed Low Limit [200 RPM]
Chassis Fan 2 Profile [Standard]
Chassis Fan 3 Q-Fan Control [Auto]
Chassis Fan 3 Q-Fan Source [CPU]
Chassis Fan 3 Smoothing Up/Down Time [0 sec]
Chassis Fan 3 Speed Low Limit [200 RPM]
Chassis Fan 3 Profile [Standard]
OnChip SATA Channel [Auto]
OnChip SATA Type [AHCI]
USB3_1 [Enabled]
USB3_2 [Enabled]
USB3_3 [Enabled]
USB3_4 [Enabled]
IR Config [RX & TX0 Only]
SdForce18 Enable [Disabled]
SD Mode configuration [AMDA]
Uart 0 Enable [Enabled]
Uart 1 Enable [Enabled]
I2C 0 Enable [Enabled]
I2C 1 Enable [Enabled]
I2C 2 Enable [Disabled]
I2C 3 Enable [Disabled]
GPIO Devices Support [Auto]
ESATA Port On Port 0 [Auto]
ESATA Port On Port 1 [Auto]
ESATA Port On Port 2 [Auto]
ESATA Port On Port 3 [Auto]
ESATA Port On Port 4 [Auto]
ESATA Port On Port 5 [Auto]
ESATA Port On Port 6 [Auto]
ESATA Port On Port 7 [Auto]
SATA Power On Port 0 [Auto]
SATA Power On Port 1 [Auto]
SATA Power On Port 2 [Auto]
SATA Power On Port 3 [Auto]
SATA Power On Port 4 [Auto]
SATA Power On Port 5 [Auto]
SATA Power On Port 6 [Auto]
SATA Power On Port 7 [Auto]
SATA Port 0 MODE [Auto]
SATA Port 1 MODE [Auto]
SATA Port 2 MODE [Auto]
SATA Port 3 MODE [Auto]
SATA Port 4 MODE [Auto]
SATA Port 5 MODE [Auto]
SATA Port 6 MODE [Auto]
SATA Port 7 MODE [Auto]
SATA Hot-Removable Support [Auto]
SATA 6 AHCI Support [Auto]
Int. Clk Differential Spread [Auto]
SATA MAXGEN2 CAP OPTION [Auto]
SATA CLK Mode Option [Auto]
Aggressive Link PM Capability [Auto]
Port Multiplier Capability [Auto]
SATA Ports Auto Clock Control [Auto]
SATA Partial State Capability [Auto]
SATA FIS Based Switching [Auto]
SATA Command Completion Coalescing Support [Auto]
SATA Slumber State Capability [Auto]
SATA MSI Capability Support [Auto]
SATA Target Support 8 Devices [Auto]
Generic Mode [Auto]
SATA AHCI Enclosure [Auto]
SATA SGPIO 0 [Disabled]
SATA SGPIO 1 [Disabled]
SATA PHY PLL [Auto]
AC/DC Change Message Delivery [Disabled]
TimerTick Tracking [Auto]
Clock Interrupt Tag [Enabled]
EHCI Traffic Handling [Disabled]
Fusion Message C Multi-Core [Disabled]
Fusion Message C State [Disabled]
SPI Read Mode [Auto]
SPI 100MHz Support [Auto]
SPI Normal Speed [Auto]
SPI Fast Read Speed [Auto]
SPI Burst Write [Auto]
I2C 0 D3 Support [Auto]
I2C 1 D3 Support [Auto]
I2C 2 D3 Support [Auto]
I2C 3 D3 Support [Auto]
UART 0 D3 Support [Auto]
UART 1 D3 Support [Auto]
SATA D3 Support [Auto]
EHCI D3 Support [Auto]
XHCI D3 Support [Auto]
SD D3 Support [Auto]
S0I3 [Auto]
Chipset Power Saving Features [Enabled]
SB Clock Spread Spectrum [Auto]
SB Clock Spread Spectrum Option [-0.375%]
HPET In SB [Auto]
MsiDis in HPET [Auto]
_OSC For PCI0 [Auto]
USB Phy Power Down [Auto]
PCIB_CLK_Stop Override [0]
USB MSI Option [Auto]
LPC MSI Option [Auto]
PCIBridge MSI Option [Auto]
AB MSI Option [Auto]
SB C1E Support [Auto]
SB Hardware Reduced Support [Auto]
GPP Serial Debug Bus Enable [Auto]
IOMMU [Auto]
Remote Display Feature [Auto]
Gnb Hd Audio [Auto]
PSPP Policy [Auto]
Memory Clock [Auto]
Bank Interleaving [Enabled]
Channel Interleaving [Enabled]
Memory Clear [Disabled]
Fast Boot [Disabled]
Boot Logo Display [Auto]
POST Delay Time [3 sec]
Boot up NumLock State [Enabled]
Wait For 'F1' If Error [Enabled]
Option ROM Messages [Enabled]
Interrupt 19 Capture [Disabled]
Setup Mode [Advanced Mode]
Launch CSM [Enabled]
Boot Device Control [UEFI and Legacy OPROM]
Boot from Network Devices [Legacy only]
Boot from Storage Devices [Legacy only]
Boot from PCI-E Expansion Devices [Legacy only]
OS Type [Other OS]
Setup Animator [Disabled]
Load from Profile [1]
Profile Name []
Save to Profile [1]
CPU Core Voltage [Auto]
VDDSOC Voltage [Auto]
BCLK Frequency [Auto]
CPU Ratio [Auto]
Bus Interface [PCIEX16/X8_1]
These are mine, unable to hit AVX stability with anything above 3.8 but you may have a better CPU. Have a look, see how yours are different. I should note this is 100% boot proof. This never fails.
6 Jan 2011
bristol
Code:
BCLK_Divider [Auto]
SMT Mode [Auto]
Target TDP [Auto]
TRC_EOM [Auto]
TRTP_EOM [Auto]
TRRS_S_EOM [Auto]
TRRS_L_EOM [Auto]
TWTR_EOM [Auto]
TWTR_L_EOM [Auto]
TWCL_EOM [Auto]
TWR_EOM [Auto]
TFAW_EOM [Auto]
TRCT_EOM [Auto]
TREFI_EOM [Auto]
TRDRD_DD_EOM [Auto]
TRDRD_SD_EOM [Auto]
TRDRD_SC_EOM [Auto]
TWRWR_DD_EOM [Auto]
TWRWR_SD_EOM [Auto]
TWRWR_SC_EOM [Auto]
TWRRD_EOM [Auto]
TRDWR_EOM [Auto]
VDDP Voltage [Auto]
CPU 3.3v AUX [Auto]
DRAM R1 Tune [Auto]
DRAM R2 Tune [Auto]
DRAM R3 Tune [Auto]
DRAM R4 Tune [Auto]
PCIE Tune R1 [Auto]
PCIE Tune R2 [Auto]
PCIE Tune R3 [Auto]
PLL Tune R1 [Auto]
T Offset [Auto]
NX Mode [Enabled]
SVM Mode [Disabled]
PT XHCI GEN1 [Auto]
PT XHCI GEN2 [Auto]
SATA Mode [AHCI]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
SB Link Mode [Auto]
USB3.1_E1 [Auto]
USB3_1 [Enabled]
USB3_2 [Enabled]
USB3_3 [Enabled]
USB3_4 [Enabled]
USB3_5 [Auto]
USB3_6 [Auto]
USB3_7 [Auto]
USB3_8 [Auto]
USB3_9 [Auto]
USB3_10 [Auto]
USB2_11 [Auto]
USB2_12 [Auto]
USB2_13 [Auto]
USB2_14 [Auto]
USB_15 [Auto]
USB_16 [Auto]
USB3_1 [Enabled]
USB3_2 [Enabled]
USB3_3 [Enabled]
USB3_4 [Enabled]
Generic Mode [Auto]
SATA PHY PLL [Auto]
S0I3 [Auto]
HPET In SB [Auto]
IOMMU [Auto]
Gnb Hd Audio [Auto]
PSPP Policy [Auto]
Memory Clock [Auto]
OS Type [Other OS]
Profile Name []
Save to Profile [1]
CPU Ratio [Auto]
Thanks, I will have a play about when I have a bit of free time
8 Nov 2006
Man, feels like I'm spending my life waiting for bios updates...
Come on Asus, want to get my ram a bit higher and have my chip clocking down at idle.
Strangely after first flashing to 0604, I was able to boot with ram at 2666. Won't any more.
