That reminds me, I couldn't even go that loose on timings. Wouldn't let me go higher than like 26.
Found something interesting last night. Aside from ryzen not liking my Corsair ram at anything above 2400 despite it being able to boot at 3200 Aida 64 found the instability in minutes literally less than 5. Meanwhile memtest took2 hours and the techpowerup memtest64 didn't find anything over 8 hours.
I've just ordered some gskill rgb 4266 and hope to have this sorted, been tweaking for weeks and I'm getting bored now. I do find it funny how my ram can theoretically run fast than my cpu though![]()
This is a case of understanding what tests are stressing what subsystem, AIDA can be very good at finding cache instability.
I have had really interesting results using the information from that video. I can boot my Corsair LPX2x8GB CL16 memory @ 3200!!!!![]()
I had it with dram v at 1.42 and soc offset 0.0875 - hard as I try I cannot get it stable, but it does give hope for the future.
The first time it worked my machine started the 3 beeps mem learning thing and I sighed as I waited for it to fail - but on the second or third attempt, it booted!
Prime 95 just kept failing, whatever I did, so I've given up for now, but learned much in the process.
My CB15 was 1750 with mem at 3200 - not much quicker than running @ 2933 CL14, but quicker! Latency was down to 70ns
@Silent_Scone
Any chance of a couple of basic gaming benchmarks with RAM at 2400, 3200 and 3500 if you have it working? Even just noting min, max and averages.
teh_captainF4-3200C16D-16GVK) member: 11641 said:Hi all, WWOcUKD?
I have upgraded to Ryzen (1700 & Taichi), and currently have 16Gb of G.Skill Ripjaws V (F4-3200C16D-16GVK) in my machine. I have clocked the CPU to 3.9GHz and it sits happily at 1.35v, but after a fair bit of tinkering I can't get the RAM any faster than 2133Mhz.
I have tried to use the XMP 2.0 profile which doesn't work, and also tried manually setting speed and timings. No matter what I do the machine will boot loop and go back to stock DDR4 speeds. I am aware there will be a microcode update in May, but i am toying with the idea of sending the RAM back for a refund and getting some new stuff, only because I'd rather be able to send it back and not have to flog it for less and get better stuff in the process.
I have read that the Trident Z kits work well, and i'm looking at some of the standard colour and RGB kits rated 3200 and over (as they're just binned differently right?) as some of the faster stuff isn't much more expensive.
I've also seen some of you guys recommending a couple of TeamGroup kits too, the Dark Pro stuff?
Cheers,
Tom
I have exact same RAM and I'm currently @ 2667Mhz (14-14-14-14-30 1T). I cant go above 2667mhz thou, because RAM is dual rank and 2T. Stupid Bios wont let me force 2T mode atleast now.
I have dual rank running faster on CH6, have you tried using BLK 112.5 and ratio 35.75 with the DRAM speed set at 2666? Worked on my corsair dual rank 4 x 8GB... takes a little time to train but works fine, auto timings then lower once booting ok at 2999.
If that works try different ratios for 3200.
MSI X370 Gaming Pro Carbon Mobo lacking BCLK option, also you can't change Command rate 1T to 2T. Actually the whole Motherboard is such a joke. 180€ and BIOS is missing half the options.
