- 21 Apr 2013
Sorry Beady, missed your update.
As, above - BIOS update primarily to ensure card compatibility and better stabiliy.
Glad you're trying the card solution/clock first - nothing to lose and hundreds (£s) to gain if you were to have success.
And a moderate stable clock, for first attempt, is always a safe way forward. You can always increase if you feel the need - i like to lean towards 'a decent clock to voltage ratio' rather than maximum sustainable clock.
Cooler - do you want air or an all in one solution?
And how much do you want to spend? (lots of choices and sizes)
I noticed an overall improvement with 16GB - using 64 bit windows - and more and more games are utilising this. I got it for apps but gaming was an added bonus.
No problem mate.
An air cooler I think would do the job, I have been looking at Noctua as seem to have very good reviews but don't know if I need to spend that amount. Budget is between 20-50 quid for a cooler.
Which RAM do you think I should get? Is 1600mhz definitely the most I can get out my board?
Cheers.
