You need to get a screwdriver - reasonable size head that's clean (sounds ominousWhat do I need the screwdriver for by the way? To push the pins together?
Well, that's annoying.
Turn off, unplug and remove one stick from DDR3_2.
Then clear the CMOS again - same procedure.
Plug back in and switch on - let it try and boot.
Do you mean DDR3_1?
Do you mean DDR3_1?
