They don't strike me as especially good value, what am I missing?
They strike me as a total rip off tbh! Zipp logo adds about £450 to the price.
They might seem that, they're one of the few hubsets/wheelsets which have adaptors to change them between QR & thru axle, so they have a 135*12 adaptor I can use with my SCS Diverge. Without it my wheel upgrade options are limited. I want to retain thru-axle for strength and don't really want to move away from SCS as I like to run wide cassettes so need the chainline correction.
My SCS wheelset 'options' are the
Specialized SCS Roval Control for £1400. The
Roval CLX SCS are £1500 or more. The 'cheaper' options are a
Hope SCS hub which is ~£185 alone, the cheapest I've seen a build is
$490 for a rear wheel (stans notubes) on wheelbuilder. Although there's a wheelset
£600 build from Strada, I've found very little real world info about it. All of these make the £500-600 Zipp quite appealing, especially with the name and lots of reviews on them... Hunt don't do any wheelsets with SCS, or with the Hope hub (The 4Seasons would be ideal otherwise)!
Basically going custom/self-build will require ~£250 on hubs before anything else... So rough maths of: (£30 rim, £30 spokes (24/28H), £30 rotor)*2 + £250 = £430 basic starting cost of parts...
Interestingly
Campagnolo are heading into the disc brake wheelset market...
What do you guys eat when cycling in the early morning? I intermittent fast so I never eat in the mornings (because I'm not hungry and it works). I'm fine cycling up to 60km on an empty stomach but then I hit a massive wall and die. Best light thing to eat before hand? Don't like to eat while riding.
You're really asking two different questions - what to eat in the mornings (when you're not used to eating that early) and what to eat pre-riding 40+ miles so you don't have to eat while out on the bike. Different answers to each!
I always eat, usually before my club/social easy rides of 40/45 miles I'll eat 2 slices of toast with marg and a bowl of cereal - museli or crunchy nut cornflakes (with a coffee). I'll carry a 'lunchbox bar' or granola type thing for 'emergencies' and usually a gel or two (real 'get me home' emergencies!). But I'll usually complete these ~16mph avg rides without requiring it. Something 50+ miles and/or harder (climbing)/higher intensity I'll try and have porridge (with dried fruit in) before and usually be carrying 2 of the granola/flapjack/museli type bars with the intentions of eating them. I try to not take a gel unless I really need to, as they don't agree with me later in the day, having one in the middle of the ride (with real food either side) seems to work best for me (with less uneasy/unsettled belly afterwards).
You may be onto something there - essentially the only real complaint with the Defy is the wheels - they're out of true if you so much as look at them hard, they're also made from iron.
The P-R2 wheelset which came on my Defy 1 (2015) were dire. I had them re-trued around 3-4 times and a number of spokes changed to no avail.
A ~£130 wheelset was a huge upgrade over them. Although I'd recommend looking at more of an upgrade, the
Zondas or Fulcrum
Racing 3 or 5 all being great options (depending what lacing and branding you want!). My Defy is a totally different ride on the
Shimano RS81's I currently have on it!
I recognised his bike - a kona paddy wagon
TLDR; got beaten by a hybrid.
Keep pushing!
