**Nvidia GeForce GTX 1080 Ti Thread**
Question for zotac owners.. how on earth do you get the spectra lights working? I have installed my card and there are no lights showing up at all. I bet this is something really easy I've missed.
It's faulty I'm afraid, they should work out the box.
I've heard a few instances of this now and apparently it's a plug that's not connected correctly under the heatsink, poor quality control on zotac's part unfortunately.
Really? Wow that sucks. I have installed the firestorm software and the spectra tab is greyed out.
Yep if it's greyed out it's not communicating with the software, if you have another pc to try it in then you should, but I've heard of this before, it's a plug not connected properly somewhere, do a search on Google.
One flaw in my plan. I woke up this morning and remembered that my monitor is freesync based. Should have gone g-sync I guess.
My goodness I am slow and out of the loop. So although I have a freesync monitor it is also 144Hz, so I don't have much to worry about really (I think!).
Torn between these two:
https://www.overclockers.co.uk/zota...pci-express-graphics-card-zt-p-gx-10k-zt.html
https://www.overclockers.co.uk/zota...s-graphics-card-zt-p10810d-10p-gx-10e-zt.html
Anymore news on stock of the first? Is it worth preordering?
Ordered a FTW3 Elite in Black. Shame I had to go direct to get the Black version, but you gotta do what you gotta do right. Probably be a few weeks before I get it though :-(
Can't blame me for ordering in Black right ;)
The render does make it look more like an anthracite colour. Supposedly the actually colour is black. I guess the SC2 Black is the closest thing to go off. To be honest, whichever it comes as, I wouldn't mind either colour.
Ive had a couple of just complete computer freezing necessitating a reboot since getting my pc back from overclockers with a 1080ti in it (asus).
Is this likely to be GPU or CPU related? Was working fine with the 1080 in it.
