can someone reccomend some ram for a
ryzen 1800x
msi x370 power titanium motherboard
been having trouble with my build its been stuttering and freezing and hanging and narrowed it down to either my cpu or the memory
think its the memory as its rarely the cpu
can someone reccomend a couple of kits 16gb (2x8gb)
been reading some other threads but its infomation overload
just need some ryzen compatible ram
cheers
ryzen 1800x
cheers
Still unsure which of the new CH6 bios I should try, or wait as I assume a single none beta bios is due to be released.
Running my F4-3466C16D-16GTZR - G.Skill kit at 3466mhz off XMP with Gear Down enabled, 1.45v DRAM.
Testing in HCI Memtest I got an error at 184%. How would you suggest I approach getting the kit stable?
Thanks
Where did you get the Ryzen Timing Checker Tool from?
What motherboard? If CH6, try BIOS 9945.
What's your SOC at? Maybe relax some timings like tRAS.
http://www.overclock.net/t/1624603/rog-crosshair-vi-overclocking-thread/18200_50#post_26137022
Oh sorry. Aorus Gaming 5 on latest beta bios.
Soc was 1.15v I think
I don't have any experience with that board in afraid. Though 1.15v soc should be enough for even high frequencies. Try tuning the timings a bit, loosen of a bit maybe.
Lowering VDDP can help too.
3333mhz 16 16 16 36 1T
250% HCI Memtest, 0 errors.
Rossi, what dimms are you using to be able to run with such low timings at that speed??
