no i think he means old way as in amd black editionswhat about 3733? I cant get anything above 3600.
Old way u mean manual mode with bclk?
eg just bump the multi and volts in advanced tab
Yes p state is best oc cos you can have c&q at low loads,less heat,voltage,watt cost,life spun in CPU when down clocking at low loads with less vcore.Its throttle on purpose.soc .. 1.2 is as far as I've gone .. pushed dram to 1.55 trying to get 3800 .. din't work
now heres a question for others out there ..
is there any advantage to run oc in p state ?? atm I'm at 4ghz 3600mem .. the old way ..
Actually happy to find here someone to share my experience with!
I've gone trough a lot of phases testing 2.34 before and 2.36 after on my X370 TAICHI with my 1600 and CMK16GX4M2B3000C15 CL15-17-17 v5.30 Hynix M single. Spent A LOT of time on these bioses. Time wasted.
First times I booted at 3066 cl16 or even 3200 I was tasting the victory.
I was wrong.
2.34 noticeably had problems syncing dram timings in OC page with Dram timing configuration in AMD submenu in advanced. Manual timings couldn't even being applied correctly, it was basically trash, but let forsee some potential.
2.36 better, no sync problems. But his behaviour is "not scientific". I cannot reproduce same results everytime.
I've pleayed with almost every new settings, including CLDO_VDDP, Geardown and powerdown modes, command rates and ProcODT . Simply not getting a clear scheme.
My best case with my sticks was 3200 CL 18-18-18-38 with timings borrowed from Asus Crosshair VI timings with the help of some guys with same stick as mine who was running 3200 CL16 flawlessy on his Crosshair agesa 1.0.0.6 beta (enough said..) but that with SoC 1.2v, dram at 1.43 (1.5v in windows) so waaaay more than what was needed IMHO.
ProcODT working better were 48ohms and 53.3 ohms but never had full stability (problems sometimes in memtest DOS, sometimes in HCI, sometimes in GSAT, sometimes powerdowns).
I have experienced too a lot of new error codes, wich found to be PCH and Memory related. Also some 00 codes at stock frequencies or OC that I know my CPU is capable of.
I have even tried to input manually every (I mean Every single!) timing totally avoiding XMP reading.
The most important facts that made me SAD :
Not only I gained pratically nothing in AIDA and Maxmemm test going from 2933 to 3200 but most importantly GENERAL PERFORMANCES OF 1.0.0.6 BETAS ARE A COMPLETE MESS.
Take for example BATTLEFIELD 1, with 2.34-2.36 @ default 2933 there is lag everywhere. It's like data are not properly transmitted among Cpu-Ram-PCIEX (same conditions, gpu utilization down from 85-90% to 72% almost fixed WTF? ) something not right.
And it is clearly visible in Firestrike Physics score too. Not able to get over 55 fps on the physics only.
Regarding SPD, I was beginning to think about buying Thaiphoon to do the same you thought. Writing proper manual timings on a separate profile.
The point is that I don't have an Intel platform to actually verify what the sticks are capable of to be sure the custom-xmp would work properly on the best case scenario, but most importantly, based on what I've seen in these betas, It would have been simply not worth the hassle.
I'm back to stable 2.34 STRONGLY HOPING that asrock engineers have some hynix M chips and got the same feedback as mine.
If any of you here are reading this, please report to asrock engineers . Something is not right in communication between CCXs, RAM and PCIEX . I don't know what. But I am losing performance at the exact same settings as 2.30 agesa 1.0.0.4 bios.
just seen it benjo
so....who first
me or you lol
