PM says residents will be rehomed near the area.
Did she say that when she popped down for 20 minutes to just talk to the emergency services and didn't speak to any residents?
the other problem with sprinklers in social housing is how do you stop false alarms or people setting them off maliciously
these flats will have communal areas that wont be secure and if they are anything like ours , door entry systems that frequently are not working or are just randomly buzzed by visitors letting anybody in...or more usually by somebody wedging the main entrance door open
then combine possible false alarms or activations or sprinklers with low income occupants having no inusrance
block of flats though....water travels downwardsThe way to counter this is just to have them in each apartment. They are set off by heat. So if they want to set them off maliciously they will only destroy their own apartment.
I dunno. Blimey, I'm only reporting what I've seen!Did she say that when she popped down for 20 minutes to just talk to the emergency services and didn't speak to any residents?
Hose reels would not have helped here... cant put out a fire when its rapidly rising outside the building.
Doesnt want to be heckled by a constituency that voted Labour
I can see you are not a landlord and think malicious damage to someone else's property (not "their own" apartment), is uncommon![]()
What's the cost difference between sprinkler systems and a fire suppression system that doesn't use water? I imagine a lot... but would be good to know from someone who has experience. Also if they are implementable in residential buildings.
You could end up gassing a lot of people. I am thinking of systems that aim to exclude oxygen from the fire triangle
Fuel / heat / oxygen
Water reduces the heat element.
