Caporegime
- 7 Apr 2008
- Lorville - Hurston
Was about to buy the s8 but then saw its 718 quid in amazon LOL
S8 plus? its 688 euros there.It is still £510 with shipping on Amazon Italy.
How long did it take to deliver?I bought an S8 not S8+. The S8+ is available for about 690EUR before shipping from the same place though.
It's working with my giffgaff SIM, the only difference is you get a 2-pin mains plug which is not really an issue and gives me an EU travel charger.
The important thing was using a card that doesn't incur transaction fees. I used a Monzo so got the exact exchange rate without fees.
Don't happen to have found away to get past the horrid notification shade judder have you?Yeah that's what I use, but the mod is handy if you're not on the homescreen and don't use the FP sensor gesture![]()
I had this gesture (still works)... What is strange since the big Samsung update however (where you can hide the nav bar) is that the nav bar is now white on the nova home screen? I don't remember it looking that stand out before... fairly sure it was black or transparentNova, swipe down gesture FTW.![]()
Anyone confirm if they also have this issue?
Thanks for confirming. Very frustrating.My navigation bar is transparent in most situations until the keyboard is on-screen, then it's white, which is annoying! It's definitely not white on my home screen whilst using Nova though.
Using Nova my nav bar is transparent too on home screen. Goes white when keyboard is open and same with some apps and not with others where either black or transparent.
I also keep catching the hide nav bar dot when I go for back button (on left hand side) which is getting semi annoying.
If you don't want a white navigation bar, install Navbar Apps, then settings > Colour of navbar when keyboard is open, set to black or something else. Then change the detection method if the default does not work. Do not change anything else, as it's not needed.
