Depends how often you want to fill upI suppose if energy density is the only concern but it seems a bit blinkered to brand a fuel inferior in general because one feature isn't as good.
I would welcome scrapping super unleaded in favour of E85.
I never understand why people don't just brim their tanks in their own cars either. It seems silly only putting £20 in at a time (if it's empty, and you're not just topping it up for a long journey as mentioned above!) since you're only going to be visiting petrol stations more often
It's 4.5% of the total weight of the car.When I was tuning my Westfield, I got 12 bhp more on Tesco 99 Ron vs regular unleaded. If I ever have to fill up with regular unleaded, I can switch to a more conservative map on my phone.
I don't even have to bother pulling my phone me phone out, I've got a switch on the dash and dual fuel/spark tables to switch between a ignition + VE maps for 95RON or Vpower + Methanol
Most people forgot that 9/10 cars that do use E85 are either flex fuel compatible from the factory or are using aftermarket ECUs with flex sensors meaning the economy drawback is largely bogus too.
£100 sensor, an hours wiring/plumbing and a couple of hours tuning and my MX5 would be fully flex fuel capable
You can full up with regular unleaded for a long journey, then switch back to E85 when you're done with no fuss or hassle (You also only need about 35% ethanol IIRC for all of the performance benefits)
You would need to do a lot more than that afaik. High levels of ethanol eats seals and fuel systems in cars that aren't made for it.
Does no one ever use the buttons on the pump housing display that allow you to set the exact amount of fuel you want if you're that bothered about hitting a specific figure?
They've updated the login system to be "simpler" now, and you're prompted to create a new account, then link your old account.
Only issue is that you can't, not until Monday I've been told. Who in their right mind makes a new system go live when it doesn't even work yet? So no fill-up and go usage until Monday
Good work, Shell.
Have stopped using V-Power now that the nearby costco has got a petrol station, 99RON for the same price as regular unleaded from shell, if you have a one nearby I'd recommend getting membership.
