My PC should be more than adequate to run the game on Ultra, at first I did but then occasionally is would get severe fps drops. Now I play everything on low except draw distance which is set to medium. Fps drops can still go from 100+ to 30+But that's the way it is and I reckon at some point the fps drops will be solved.
i think the problem is many newer games add all kinds of stupid blur post process bad aa types.it just looks cleaner on low like many games.
unreal 4 has a weird look in general anyway but paired with bad aa types it can look even worse even on high settings.
strange atari as one of our lot runs a ocd 2500k and it drops really bad in some places.to the fact that he brought a new rig mainly to play this.hes just ordered a 7900x and a 1080ti so massive jump for him and will be great to see him enjoy the game more.
I've got most settings on medium and foliage on low, draw distance ultra and it seems to be running ok now.
One thing that is annoying is no toggle to sprint button. I see there is a toggle to run but it doesn't seem to do any thing?
Another thing is zooming in when you have a scope. I've changed the bind to space bar and to zoom in I have to double tap it which sometimes works and sometimes doesn't, it's annoying when you're quickly trying to scope on someone and it doesn't work.
Doesn't a single click of the right mouse button get you scoped in?
I'm pretty sure that a single press of the = key does auto run. You can lock your direction and look around then.I've got most settings on medium and foliage on low, draw distance ultra and it seems to be running ok now.
go all low and view distance ultra.![]()
As for the performance the pattern amongst the guys I play with (and here so far) is that cards with less VRAM (and particularly 970s) struggle with performance...
Be careful doing this as it can make your FPS drop due to loading up your CPU and not your GPU. It also makes little difference with regards to visibility.
That is correct with all modern games that use the GPU mainly and not cpu like older games.Be careful doing this as it can make your FPS drop due to loading up your CPU and not your GPU. It also makes little difference with regards to visibility.
