Yep, i built a Skylake system 18 month ago. I don't plan on upgrading anything until 2020/2021 (TV, GPU, etc). I'll evaluate how the PC market is then decide if i want to stick with it or go back to consoles.
GPU prices are a joke. Worse when you see that there is so much parity now between PC and consoles, with the PC version just getting a higher frame rate in games and not much else. It feels like a waste buying an expensive GPU when the games aren't even taking advantage of it. The days when devs would maximise a PC title that couldn't be done on consoles are long gone.
It's all to do with parity now.
I don't get why you have to be at the cutting edge of PC's if you feel the improvement is too minimal to be worth it? If you stick in the midrange the cost is much cheaper, performance is still solid and probably above console, and you still get the flexibility and upgradability of a PC>
