So my question is... building a new itx gaming build (not putchased mobo yet) will be sat along side a 1080ti what xou do i get? I dont want to wait until oct/nov thats for sure i want to get it this weekend. I had my hopes up for a 6c i5. Budget of 250ish can go higher but really dont want too.
Do i go intel ? If so what one or do i go ryzen and if so what one?
This has all thrown a spanner in the works.
Why cant they launch them now haha
Just because Intel have been doing this for years, doesn't mean they have to. Why should the end user have to keep upgrading chipsets when the motherboards are more than likely capable of powering their CPU's.
With AMD AM4 it's going to be around for 4 years, even so probally new motherboards will be released if the CPU's are desirable, but at least the end user has a choice.
How so?To be frank, if it's ITX you are knackered in both directions.
How so?
£250 is for cpu alone
How so?
Buy AMD then, I'm more than happy to keep the same CPU/Mobo for 5 years, seems like you are too with a 2500k, no idea why it bothers you!You sound abit grumpy. Just because Intel have been doing this for years, doesn't mean they have to. I think their should be more choice, why should the end user have to keep upgrading chipsets when the motherboards are more than likely capable of powering their CPU's.
Like I said with AMD AM4 it's going to be around for 4 years, even so probally new motherboards will be released if the CPU's are desirable, but at least the end user has a choice.
i dont mind dishing out a couple of hundred on a mobo too. Size really is key on this build. The biggest case i could use was the node 202 so i have to work with that.Because ITX for AM4 are an arm and a leg and not much choice. Intel are much the same if it's for gaming.................after all you did say it was a gaming rig. What's your total budget then ?
I
Im just so confused what route to take
Thats micro atx not itxWell, if the route was to be AM4 you could do a lot worse than the Asrock AB350M HDV Micro ATX @ about £64. Tag that with a 1600 or 1700 and you is good to go.
BIOSTAR X370GTN AM4 AMD X370 SATA 6Gb/s USB 3.1 HDMI Mini ITX AMD MotherboardThats micro atx not itx![]()
Max/avg are lower or equal depending on GPU but minimums and frametimes are better in newer engines. I imagine it will be the same with the 8700k. Dont get a 4 core CPU now.I dont know why but somthing is still telling me to go 7600k as its going to perform better in games
Plus boards and memory are cheaper. I have yet to see any games perform better with ryzen
Yeah.Pff quad core. The 7600k just got wasted by the R5 1600 in a recent digital foundry review. Unless you are eye balling fraps 24/7 you ain't gonna see the difference between zen and any Intel. Bigger things in life to worry about than a few fps lol.
Fair enough will go ryzen then. The "X" models i assume are just pre overclocked? Or do they hit that clock on stock non x voltages? Heat is my enemy in this build so if the "x" boosts to 4ghz on the same bolta a non x does its a winner for me. I assume im better of with a ryzen 5 over 7 due to higher clock speeds and still having 6c/12t?
Intersting cheers for the tip. So the question is x or no x? Realistically im going to be using a low profile cooler with a trp of 95w the c7 cryorig is about the best i can fit in the case so is overclocking even going to be on the cardsThe X = XFR. A 2 core boost. But if you overclock them, they lost it.
What you need to make sure you buy good compatible ram running 3200C14 or 3466C14. The fps improvement over slower ram is huge. (40% between 2133 and 3466)
