Intel Core i3-8350K CPU Performance Leaks. Faster than an i7
Are they having a laugh?
http://wccftech.com/intel-coffee-lake-core-i3-8350k-cpu-benchmarks-leak/
“The Core i3-8350K scores 503.3 points in single threaded and 1982.0 points in multi-threaded.
The Core i7-7700K scores 492 points in single threaded and 2648 in multi-threaded.”
If Ryzen is overkill then why would you spend even more on the 8700k? For playing old games how much IPC do you really need to make the game run really well?
Also why move from a 1070 to Vega 56? They are almost the same performance wise. Plus Vega doesn't overclock at all and you can usually get a decent OC on a 1070.
Not really trying to have a go, just want to understand your motivations a bit more![]()
is this still coming in august (few days left), feel kinda stupid buying a z270 board when this is about to be released.![]()
Depends if you're going anything besides gaming. For just gaming, with a Vega 56 it's probably not worth going for the i7-8700K. With a GTX 1080 Ti or maybe GTX 1080 it might make sense if playing at 1080p. Otherwise Ryzen is sufficient and saves a lot of cash.Yeah should have said i have a Freesync 1440p 144hz Screen so i want to go back to an AMD Card, i will give the 1070 + 4770k rig to my kids, can always keep the CH6 for future projects should Ryzen v2 be decent as well.
With regards to CPU change, i just feel ive had this 4770k for a good few years now and just fancy a change mostly, also i can move to DDR4 and m2 etc, i have a 500gb m2 drive waiting as well, which was for the Zen build etc.
Basically the real question is, do i go with Ryzen or do i go with 8700k, im guessing the IPC deficit on Zen is going to not be noticeable really in the type of game i play (EQ can be played on a 2500k igpu without issue lol), and i guess the AM4 socket is going to have a longer lifespan than the Intel Z370 socket as well? I ruled out the 1600x purely on if im going AMD cpu for the same price i would pay for an Intel 8700k i can get a 1700 etc.
November is a little late imho to release
End of October, beginning of November is looking like the dates most likely. So all in only 2 months earlier than they would have launched if they followed the normal refresh cycle, which would have been Jan '18.
Great marketing from Intel, with the leaks pointing towards August however, keeping people from possibly jumping to AMD.
Fed up with Ryzen? or looking for something more powerful?They can release it when they like, I'll be jumping from AMD.
October would be nice though.
So your overclock isn't stable? :|Cold boot bugs are annoying AF when running >3200 ram and I'd like more IPC tbh.
Seems every bios update asus seem to break something else too.
