Ok, I bought this rig in October I overclocked it exactly as it showed in the pictures apart from the default voltages in the black boxes were not the same as the pictures. It did work for afew weeks but then it wouldn't let me play games like overwatch and doom. I would be half way into a match and it would just crash. Long story short I phoned OC and I was informed that my mobo had broken so it needed to be replaced. That was during Xmas so I didn't actually get a replacement until January 6th. Anyway, from that point on I didn't want to overclock it again in case the same happened again. This weekend I had a performance issue during a LAN event, when I got home I thought I would give overclocking ago again. Exactly to the pictures and it's broken again. It will not go past the boot screen. I've even tried to set it back to default but it's the same. Any help would be appreciated before I get back on to OC tomorrow. Thank you in advance
I'm running this set up with a 1080
UPDATE:
Ive got it booting now. I've tested it in game, I can run CSGO everything set highest. No issues at all can play for hours. Runs perfectly. However in overwatch, it can play for so long then it will just crash.
UPDATE:
