Pro carbon is not great. But for me 16gb working easy 3200c14. Manually set everything then 3200 should work easy.
I am testing 8PAck 3600mhz now with MSI Carbon X370?? 2x8gb Set profile 1 from AMP and it goes straight in C16 3333mhz on my rig. Just running mem test now. All I did was set AMP profile one and set Vram voltage to 1.45v then zero issues. Will post screens after running mem test for a while.Yup, no-go unfortunately. I'll look to try and swap it back for the 3200.
<snip>
MSI Carbon 3600mhz 8Pack kit 2x8gb sticks 3200mhz C14
Are you on the same bios as me?? I am beginning to think your CPU CACHE or IMC potential is really bad as I am having no issues at all here on that board with 2x8gb configuration 3600mhz 8Pack Dark Pro
Thanks for testing. Certainly looks that way. Same BIOS, exactly the same settings through timings, voltage and speed. Complete failure to boot at anything above 3066, nothing stable above 2933.
Crappy chip on my part? :S
Got g Skill 3600c17 kit stable at 3466, 14-14-14-28 1T, tRC 44 and tRFC 275 with new gigabyte BIOS today. Super tight timings and very quick! 1000% HCI stable.
From experience HCI memtest needs at least 400% and preferably more. I failed a lot at 200-300% today either errors or restarts. 200% is not enough.
Remember IMC is very sensitive to SOC voltage. Try every setting between 1.1 and 1.15 when testing. Voltage too high is as bad as too low.
Do you think a system rebooting before bios a few times then starting at a lower speed is a sign of low voltage?
