I have also turned down a trip to the pub after work...
Is there room in there for your eyeliner and mascara?
so my 5Ghz rated OCUK binned/delided 8700k is now at 5.1Ghz @ 1.35v Its running at around 70c after 30 mins on water on prime95 (small FFT). Ive got 2 x 240 Rads with CPU & GPU in the loop.
I may still just roll it back to 5Ghz for every day but its impressive.
Please update us on performanceSeems as though I wasn't lucky enough to be quick enough to get a 8600k, would have had a dispatched email by now so changing to the 8400 as it's best value - build was going to be for eldest brother , happens that youngest needs a bit of an upgrade to- i7 860 and I changed that same chipset this year so now how much improvement he'll get .
Also, since I tend to quote a lot of Ryzen builds it's will be interesting to see how this Intel fairs. Did see gigabyte and ASRock boards for under £110 but then rides the Gigabyte to £120....![]()
Hmm...to ditch my 4770k or not.
Can’t see any ASUS micro atx board.
What better must have features will Z390 bring?
That could well be the case. Coffee Lake was clearly rushed to market as a response to Ryzen taking market share away from Intel, I wouldn't be surprised if Z390 was "what Z370 should have been". Maybe Z390 will be forwards-compatible with Icelake but Z370 won't, who knows.Honestly don't know but they were meant to be for the 8th gen processors and they are rumoured to support 8 core processors which would either mean they have an upgrade path on 8th gen / refreshes and an 8-core 8th gen variant or they will work with Ice Lake? Knowing intel it's probably none of the former and is actually just the board that they were meant to release on and Z370 is in fact just a knock on effect of the rush job that has affected board manufacturers
Also maybe more PCI lanes, DDR5??? Anyone's guess
Hmm so probably Z390 will be another dead end board and no point waiting unless you also want the 8 core if there is one.
I cant see Intel not releasing a new chipset for icelake![]()
Kaby Lake -> Coffee Lake
VSS (Ground): 377 -> 391 (+14)
VCC (Power): 128 -> 146 (+18)
RSVD: 46 -> 25
Z390 is supposed to integrate wifi, bt and usb 3.1 gen 2 (10Gbps).
And the reason they've made Z370 Coffee Lake only is because they're using more pins for VCC on Z370, 146 on Z370 vs 128 on Z270.
You can find the info in their 8th gen datasheet here: https://www.intel.com/content/www/u...cessor-family-s-platform-datasheet-vol-1.html
@DarkHorizon472 10% is putting it mildly for 1080p, probably GPU limited tests because in the reviews with a 1080 Ti the difference is higher.
They were with a 1080 over several difference games, I don't have ninja like reactions that need over 144FPS
To be honest anything over 60FPS would match my skills![]()
