Providing both the price and performance sit between an overclocked 1070 and 1080 then this is a non-issue for me.
edit: almost all my AIB purchases have been made based on cooling/noise, and that still stands
Locking out the user from overclocking is not good though. It's your GPU, you should have the freedom to do what you want to it.
I myself isn't a big overclocker, I run my GPUs at stock most of the time but I wouldn't still like to buy a GPU that is locked.
The 1070Ti should easy be able to pass the 1080 with tweaks to the core.
probably just dont want it ending up faster than a 1080
This isn't going to go down well...
We are fairly confident that Nvidia is readying a GeForce GTX 1070 Ti graphics card that slip into its product lineup between the non-Ti variant and the higher-end GeForce GTX 1080. However, if you are hoping to squeeze out GTX 1080-like performance through overclocking, you might be in for a rude awakening—the latest rumors suggest Nvidia is locking the frequency on the GTX 1070 Ti.
Bearing in mind that none of this is official, the rumor traces back to two sources, and the reports are slightly conflicting. Eteknix says it heard from an "industry insider" that the GeForce GTX 1070 Ti will not support overclocking in any way, shape, or form. "In addition, we've been informed that Nvidia will not release any reference cards and all AIB (add-in-board) partner cards will be locked to the same speeds. However, price and aesthetics are expected to differ across partner cards," Eteknix says.
http://www.pcgamer.com/you-might-not-be-able-to-overclock-nvidias-geforce-gtx-1070-ti/
I can't see this being true and quite surprised to see Shankly caring, as he has stated he will never own Nvidia.
Nah, I am not up for baiting, so won't reply.Like I told someone else. I still care and follow the PC platform. Just because I wouldn't buy nvidia does not mean I stop reading up on anything the PC platform had to offer.
You have a quoted post waiting for reply in another thread![]()
I'm not one for criticising other people's purchase choices, but anyone who supports such a cynical attempt to stifle the competition and the consumer should really think twice.
Asus said end of October for Strix 56 but i suspect price will be higher than the reference card.Well the thing is, I need a new GPU and was waiting patiently for an AIB Vega 56, but where the hell are they? No word when or if they will come out so of course I will eventually give up and go back to NVidia. I don't think they are stifling anything, it is AMD's fault people like me are likely to do this.
