Newer driver?
You'll need to change the DNS address in your network adapter then in Windows.
Hope you are having fun with the new build.
Ha found it on the Advance Mode of the router config. Changed it but need to reboot it, while downloading stuff. I will reboot the router tomorrow.
Otherwise I am very happy with the service. Atm is downloading WOT at 8.3Mbyte per second..... bonkers speed. (66.7mbit connection atm).
Haven't seen such connection since the NTL/Virgin days when I had cable broadband on my old house, Leeds.
(ok no need to reboot, worked straight away)
