Newer driver?
You'll need to change the DNS address in your network adapter then in Windows.
Hope you are having fun with the new build.![]()
Ha found it on the Advance Mode of the router config. Changed it but need to reboot it, while downloading stuff. I will reboot the router tomorrow.
Otherwise I am very happy with the service. Atm is downloading WOT at 8.3Mbyte per second..... bonkers speed. (66.7mbit connection atm).
Haven't seen such connection since the NTL/Virgin days when I had cable broadband on my old house, Leeds.
(ok no need to reboot, worked straight away)
