- 19 Apr 2013
- Scotland
I'm not sure if it's a memory leak as resource monitor, afterburner etc don't show an increase. But the fps drop is real after a while.
Worth me buying this? I heard this game was far too easy from the console side.
do you dismantle everything you don't use?
If that is truly the case, they have lost me as a customer.
Did people even get their overlays working? I had MSI running but it didn't display so I used the ingame fps counter instead.
I understand the sentiment, but a ban without any way of questioning it? I have corsair link running for my h100, so by the sounds of it that would could cause a ban? Not good enough i'm afraid.
Glad a few others experienced the same, thought I was going madThere are issues...
Feels like a memory leak after a while... FPS drops and game becomes jerky.
Yes 90% of the time, except save 5 blue/rare scout rifles (either primary or secondary slot) for later. You can lock items using Shift.do you dismantle everything you don't use?
