Permabanned
- 23 Apr 2014
- Hertfordshire
Vid just shows either will be decent, good to have a choice.
720p 16 bit colour on X34 is the future of gaming.
Sounds normal for a fullscreen application.
3.7Ghz with 1.26v seems decent. What motherboard did you get?
I was obviously joking but there is no other way to show it the difference, other than that on lower resolution. I will wait until Rezen + and see what that will bring to the table, hopefully higher clocks.Should they do CPU testing at resolutions where you're GPU bottlenecked then? If you get the i5 8400 today and later on upgrade to a Volta GPU that 720p difference between the i5 8400 and R5 1600 will show up at higher resolutions.
But hey, might as well get a Celeron since at 4K in gaming it will have the same FPS as the much more expensive 8700K or 1800X![]()
For pure gaming, yes.i5 8400 seems to be a much better choice for gaming based on that video, it's faster than a 4Ghz R5 1600, which isn't something most R5 1600s can even reach at <1.425v.
You also don't need 3200Mhz B-die with the i5 8400, 2666Mhz DDR4 seems to suffice.
Eh, I don't see why. The R5 1600 is still a great all-round choice, AMD and Intel don't price parts just for gamers. A very small price drop might be in order but they can't go too far because of the 1500X anyway.AMD needs to cut prices a bit.
Depends on the game I guess. I always expect a slight delay when alt-tabbing to/from a fullscreen game, and a bit of lag for a second or two after restoring. Are you sure you always played in fullscreen and not borderless windowed mode?Shouldn't be, not for a game like league of legends; well I hope not anyhow.. never had stuttering when minimising the game with my dated ivy bridge xeon e3 1245
Except you can't really get an i5-8600K now. You're also assuming that everyone upgrades their GPUs and/or CPUs every generation, that just isn't the case for the vast majority of gamers, let alone other users. If I were to get an R5 1600 now I doubt I'd upgrade it until we're towards the end of AM4's life cycle, and I probably won't get a new GPU until around then either.
No difference yet. But it will show in future gpus. Ofc you can get the 1600 now and upgrade when zen2 comes but that's poor value for money when you can get something like the 8600k now and not have to worry about upgrading in the future.
My thoughts, don't shoot me!
Eh, I don't see why. The R5 1600 is still a great all-round choice.
Yeah this advice is for people who are looking to buy systems right now, if they can find intel CPU on shelves.
Maybe but if Zen+ really does come out in February they might not bother.I think the price cuts will come when the cheaper boards from intel arrive.
How do you use that?New version of ryzen memort calculatir up and separate topic just about it:
Http://www.overclock.net/t/1640919/ryzen-dram-calculator-overclocking-dram/30#post_26420488
You have an 'Instructions' tab in the first post of that thread that walks you step by step.How do you use that?
Ymmv with that calculator, but it seems to output good timings.
What is the actual point of the calculator? Why should we be using it?
