sitting since release-ish you mean? Either stick 1701 or 0052 on a usb stick (preferably with an activity light on it). name the file C6H - stick it in the motherboard usb bios slot (indicated on the back panel) and with power to the motherboard (but not turned on) hit the bios update button.Hi guys, had a CH6 sitting in a box for a few months waiting for a CPU, just bought a 1700X today, turns up tomorrow.. Whats the best bios for this motherboard and where can i find it? i read some of the Beta BIOS are the best to run? also do i need to download and install the AMD drivers off the AMD site for the chipset etc?
sit relax. wait and go have a brew and wait for the activity light to stop. i leave it 10 mins just to be sure, then boot up as normal. you have just updated the bios with power off. Safest way if you are on the old first few bioses that could brick the mobo.
beta bios links are on this first page/post by an Asus employee.
http://www.overclock.net/t/1624603/rog-crosshair-vi-overclocking-thread
Do chipset install once everything else has settled down and you can boot into windows and do graphics drivers as well.
Also I guess this should be done when the PC is powered down, while I'm in the UEFI or can this even be done while you are in windows
Do it powered down. with the mobo lights on but the pc not turned on. wait for the lights to come back on, then power up as you would normally.
Well done! that's a lot better than most manage! luck is with youI have managed to get my GSkill GTZ(A) 3600Mhz to run at the stock speeds of 3600 on the latest BIOS.
