Is that 8700 from the rainforest?does MCE work on the 8700 non K? If not is there any other way of forcing all cores to boost to max?
Got an 8700 coming next week, only cost 269, but would like to know if that functionality is reserved for the K variant.
I plead the fifthIs that 8700 from the rainforest?
That is respectsble for a 4 dimm board.Latest bios version 0802 on maximus hero allows me to boot at XMP (4266) but its unstable.
The highest I can go with a 5ghz overclock in place is 3866 CL18 but its stable at least.
I can go 4000mhz with the CPU at stock but the gains from the CPU overclock are larger.
With the strix itx my chip passed 2hrs Realbench 5.2 core, 4.4 cache, 4000 17-17-17-28. AVX offset 0.
Testing 4000 16-17-17-28 and 4.9 cache now. Seems solid so far (32 minutes).
3 faults up until this point:Very impressive!
The strix itx is a brilliant little board.
1. Can't run memory at 1T
2. Can't go higher cache than 4.9Ghz
3. Can't use EK Supremacy block with my rams
I am honestly thinking of selling this board off and get the Asrock Z370 Faltality, been hearing a lot of good things about Asrock Z370 series so far.
probably needs more updates to the bios.Points 1 and 2 also apply to me so maybe an asus thing?
I originally wanted a taichi but there were none in stock at launch.
@Panos hi there, can you check if the strix board on latest bios can run a higher cache than 4.9Ghz?
Cheers buddyI will when I have the time![]()
cheers for that, new chip coming between 23-24thYeah mce works on the 8400.
But it's kind of works better just setting the clocks manually as it uses less voltage and boosts slightly higher with mce off.
You can set the clocks and stuff the same as the K you just can't go higher than the boost.
cheers for that, new chip coming between 23-24th![]()
Think I'm going with the Asrock K6 and already have some Corsair 3200 and a Kraken X61.
)Cheers buddy
Just passed 2hrs Realbench test 5.2Ghz core, 4.9Ghz ram, 4000 16-17-17-28-2T.
Kraken X52 silent fan profile, but I got the window open so the intake air temperature would be around 13-15 degrees.Seriously good temps! What cooler are you using?
