Thanks@haszek Your build looks immense, i really like the loop layout.... The colour choices are on point to![]()
before...I just couldn't setup LEDs properly, too dark, too bright, not visible this or that. With this block I could light up the center, add colour to tubes and didn't even have to use dye (which I have, just decided not to use after build).They were probably hosted on sites that no longer provide free hosting so are blocked.On a completely unrelated note, when did the forum loose all of it's old images? I just went to check out my old WC system and there's just a bunch of[IMG ] tags![]()
Like the water temp gauge!
Looks very clean, I like it. Can you change the RGB lights on the memory to white (or grey) to match everything else?
Ahh okI normally have them set to White, Blue or off but with the current issues with the Aura software I've left them on the default settings for the moment.
you would tell my OCD really bothered me. Great build and look!A few updated shots of mine
where you get the water temp dial m8y
Here is mine! completed a couple of weeks ago.. Love the 570x
Very nice build and great cable management. What fluid is that, really like it.
