Hmm. I cannot see the Rename button..just apps etc..![]()
Apps? Are you pressing the Input button on your remote? Sounds like you're pressing the home button or something.
im pressing the input, then when go up it has, different quick links, but no name input..mabye there are no settings..?
on mine (not same model) I get this layout :
no problem, thanks for the input though mate.Ah no idea then!
On mine it's in setup>all>system>advanced settings>input labelsJust sorted out my settings on TV, it IS a HDR , im such a NooB
One thing, anyone know how to rename the Source to "TV" "XBOX" etc..
checked the net and manual but can't find a thing!
TV is a HiSense H49M3000.
Cheers.
Pun intended?![]()
No problem. It's usually me asking for advice so it's nice to give something back for once lolHaha, no, but well spotted
LEGEND, thanks mate, got it.![]()
As far as OG Xbox is concerned I would say it's worth upgrading, 4K, HDR, UHD player etc etc (obviously if you go down the 4K TV route).
Whether it's worth trading in a PS4 as well.... not so sure it's worth losing the ability to play the PS4 exclusives if you're still on 1080P.
