I see they've gone with the Escudo Pikes Peak look
Seems very much a function over form design consideration. Yes it's not pretty, but it's clearly designed as a car to go fast round a track, not look pretty on the street.
So since a car is trying to get the opposite of a plane, downforce instead of uplift then it should be as ugly as possible?
I expect it's substance over style and I kind of implore them for taking that stance.
I like it because it looks like an engineering masterpiece.I really like the look of it because I can see the functional elements they've taken out of what looks to be F1 design basics and tweaked it to be compatible with a road car.
Looks awesome from the rear.
Do not like. It just looks... Wrong somehow.
I don't think the rear wing suits it, and the see through doors are stupid.
This is track only right?
It's aesthetics are acceptable for the track only, right.
the wing is the only thing that's truly wrong..........the car is flowing fore and aft, but the wing is going dead vertical and way too heavy looking, it needs two small wings attached to the end of the side panels, like the Lola has...........but this might not generate enough downforce
I'm with you guys!Exactly![]()
Exactly![]()
I'm with you guys!
