My Noctua D15 arrived along with the LGA1366 mounting kit from Noctua, not without some chasing up though, which was a shame. After installing the D15 cooler, my temperatures are instantly lower compared to the Cryorig H5 I had earlier. What an excellent purchase. Well worth the money, and mounting it was very easy.
I'm currently running at 4.5GHz with 1.43v IBT stable. But I'd like to know if I should bump the voltage higher for 4.7GHz.
So can someone from their experience please tell what voltage is a safe to preserve the life of this X5650 for say, 18 months or so?
Is 4.7GHz at 1.525v being a bit greedy with the voltage?
I don't go over 1.35 V, which I think is Intel's recommended maximum, and it's lasted years. I think 1.4 V would probably be fine for the medium term though, lots of people go that high according to forum posts here and elsewhere.My Noctua D15 arrived along with the LGA1366 mounting kit from Noctua, not without some chasing up though, which was a shame. After installing the D15 cooler, my temperatures are instantly lower compared to the Cryorig H5 I had earlier. What an excellent purchase. Well worth the money, and mounting it was very easy.
Personally I wouldn't have it over the offiical vcore at all. Also temps shoot up, when I left it to auto it set it to 1.4v, manually decreasing lowered it by 10 degrees, and 4ghz (1 gig overclock) per core is good enough, and rather have it last longer than risk damaging it.
Sounds cooler than my chip. At ~4.14 GHz @ 1.35 V it easily gets to the 80s when doing long x264 encodes in summer. My ancient case probably doesn't help though; that's one thing I would put much more thought into for a new build. Better airflow would work wonders, I reckon.Thank you for your informative response.
With this processor being so cheap right now, I'll think I'll go with 4.5GHz at 1.43v and see how it goes. From the testing I have done already, it's perfectly stable. The temps never go beyond mid 70s under stress load, hence my reason to over volt a little.
It would be a different story had I bought this brand new or spent 3 figures. But the reality is as we know it. Thanks again.
Saffy has definitely won the silicon lottery! I thought getting mine to 4.4ghz at 1.44v was good!
I agree that the CPUs are cheap right now, so there is little concern about pushing voltages... but, if something does go wrong, what are the chances of killing the mobo and memory at the same time, which cannot be replaced for £40?
No, AsusThat a gigabyte mobo on ebay by any chance?
Memory was an issue at 16xxMHz because the DIMMs are different, but they complied when turned down to 1233MHz. Max CPU temp was a cool 71°C.
