Thanks for all the responses, plenty of food for thought.
I do like the look of the fiesta, but with a 2yo I think we’d struggle for room, and I think the focus is pushing it a bit too, to be honest.
I’ll probably end up buying a Mk3 VRS instead, but I definitely want to test an ST first before I go down the “sensible” route.![]()
None in mine to be fair
It just chucked it's internals everywhere instead
Yeh just check for smoke coming from exhausts, loss of coolant, lift the dipstick out while engine is running to check oil diaphragm hasnt gone etc. Will make a noise if it has.The cars I've seen one is at 44k and the other 55k. I can obviously check if the symptoms are there on viewing. I seen the monotune one but don't prefer the colour.
What colour where u looking for? Performance Blue or Orange are the only 2 colours to have an ST in imo
. Prefer the outlandish colour in this. Don't get me wrong, I do love the blue, I also like the silver as it's understated. Though I feel if I am buying one I may as well go orange.I said that when looking for mine but just gave up in the end and went for my second choice Performance BlueOrange. Prefer the outlandish colour in this.Though I feel if I am buying one I may as well go orange.
. Your really limited for choice with Orange as there’s not that many and some can look really faded if they have not been polished over the years. Not to mention getting a colour match for any re sprays. I’m sure the facelift 2008+ had a slightly deeper orange on it which looks nicer and also probably why Ford couldn’t even match the paint properly during repairs lol. Check coolant, Smokey exhausts, oil diaphragm any noticeable vibrations through the wheel will probably be driveshafts which are quite expensive.Yeah I guess you're right. Sometimes having a car which goes under the radar can be a good thing.
Is there anything else to check out for apart from the usual rust, clutch slip, driveshaft clicking etc?
