I would hardly call the MM "deals", people are deluded with some of the prices in there.
lol exactly what I thought. Over £700 for 2nd hand 1080Ti is mental
Then don't max them? Going from max settings to literally one setting down usually listed as very high or high from max makes almost not difference visually. You have to have a still screen, or take screenshots of the same scene to play spot the difference. However the performance difference is noticeable going from max to one setting down. There has been many reviewers pointing this out and gaming like this at 4k a 1080ti can cope fine usually attaining over 60FPS. But however still not quite achieving that 100+FPS or near it. Possibly peaks but near there but averages are some what lower. For you Kaap you have the best and usually more than one card going when gaming so i get why you love to smack max settings. But for most run one card at enthusiast such as a 1080ti or titan X or XP. Only a minute few run more than one and you will find them on these forums. So 4k is possible and over 60FPS on quite a few titles but it has to be at reasonable settings. These are who these monitors are for. Not to forget for FPS games going to 4k and lowering quite a few settings to mix and match to get good visuals as well as 100FPS plus can mean a lot competitively. Trying to shoot some one at distance a 4k screen can make a big difference vs 1080p or 1440p because of the PPI. Makes it easy to spot people at range as well as aim.There won't be any single GPU solutions in the next few years that can drive 2160p/144hz anywhere near maxed. To do it you would need a GPU packing around 50 billion transistors and that is not going to happen for 4 or 5 years.
1080 was launched at £600+ (forget the BS RRP £550), so we can well expect the 1180 would be at £650+
I wish you would realise this sometimes lol.
You can get some good deals in there.
ATM I have an EVGA 1080 FE in there at a very reasonable price and don't forget the warranty you get with their cards.
Having said that I have seen some stuff at silly prices.
So lets take yours as an example then, I personally don't think that the price represents particularly good value for money.
I can buy (today) a brand new 1080 (albeit a different model to yours) from OCUK for £80 more than your used card.
Your price is not out of line with other 2nd hand 1080 prices but for me a 2nd hand part should be considerably cheaper than buying new, £80 just doesn't cut it for me, I would rather take a new card and know that it has no issues or history.
Especially as your card is a FE edition, which (correct me if I am wrong here by the way) is basically the vanilla version of a card and for some odd reason carries an (unwarranted) price premium.
The complaints about max settings are utter rubbish: game developers can always add more settings to tax the GPU. All that matters is, 'Does it look good enough?'
It's got nothing to do with E-Peen, if I invest a couple of grand in a system then I don't like making compromises. It's no more complicated than that.
My 1080ti is a great match for 3440*1440 and whilst I would like to upgrade my monitor to 3440*1440 @ 200Hz, I won't be doing so if the 1180ti can't do it justice.
So your saying everyone should play on high settings and buy AMD cards?It isn't a compromise but smart management of the available resources. If you waste your GPU for "effects" which you barely see at all while gaming, why bother?
It is e-peen, yes![]()
This.It's got nothing to do with E-Peen, if I invest a couple of grand in a system then I don't like making compromises. It's no more complicated than that.
