- 27 Apr 2011
- UK
You can say it's better all you want, still not playing that map. You can't polish a turd but you can roll it in glitter
Gamblers' prisonglitter turd is better than erangel with no loot
nearly forgot to post this was crying with laughter when this happened last night
dont know who hawkeye is on here but he got trapped in the vending machine.so funny.![]()
That goes without saying! LolYou are an ass![]()
Aye. Wouldn't matter if there were slr's in every room. The map layout and design is aids. Granted they tried to improve it a bit with added dirt tracks through the almost totally undriveable terrain but it's not enough to redeem it. At least that's my opinion and to be honest that's all that should matter.You can say it's better all you want, still not playing that map. You can't polish a turd but you can roll it in glitter
Could be. I hear the guys I play with talking about massive drops randomly with much higher end gpu's than me. My 380x tends to hold a relativley steady frame rate. +/- 15fps is usually my max sway. Admittedly my max is only about 70 from memory.Hey,
Does anyone have a good link to recent PUBG GPU benchmarks please?
The most recent I could find was from a German site in March 2018 (1440p High present, using Adrenalin 18.3.1 and GeForce 391.01). They show the Radeon cards with a lower but perhaps more stable fps. Is that a fair representation?
Cheers,
Su
Hey,
Cheers,
Su
I'm looking at that spec PC when I upgrade in a few months. It will be nice going from 50-60fps to 120+I have 8700K @ 4.9 and a 1080Ti per sig. I play at 1440p with AA and View distance on Ultra and other stuff med/low from memory. Sits at 144 mostly and dips to 120ish when in a built up area or lots of players. I notice its always lower when playing squad over solo but I guess thats due to 3 other playera always in close proximity.
.I'm looking at that spec PC when I upgrade in a few months. It will be nice going from 50-60fps to 120+.
I can check what happens in Pochinki - any part in particular or just bang in the middle?
I'll tell you what, when I get on later, I'll try and find you on discord - we can both jump in a game and jump pochinki and compare within the same room?
I'm having a very annoying issue at the moment. I have V-Sync enabled so I don't get screen tearing and in the past the game ran at 60 FPS with only the occasional drop of 1 or 2 FPS. Recently, when I go in buildings my FPS halves, literally straight down to 30 FPS, as soon as I walk out it goes up.
Running a slightly overclocked 2500k, 16GB memory, and GTX1070. Operating system and the game are on an SSD. Settings are all ultra apart from post processing on medium I think. Have tried updating to latest drivers and it still does it but dropping to 40 now instead of 30. Anyone else getting this?
