- 5 Feb 2009
Another one incoming! Just waiting for case and SSDs to arrive tomorrow. Getting excited!
I really do not want to be that guy... but check the VRM heatsink on the Gigabyte before you break the seals if you plan to put the APU in it.
(Hint; it doesn't have a heatsink on the SOC mosfets. I'm genuinely sorry to ruin your moment, but you probably need to know. In your place I would return it unopened and get a different board. Sorry.)
Argh. Really? Anything I can do other than returning it? (Spot fan cooling, for example?). Any other mATX Ryzen board that would work better with a Raven Ridge APU?
Edit: It is still unopened at the moment.
No heatsink at all on the SoC VRMs, I don't believe fans can help much. I mean, check online, see what other people's experiences are, but... yeah, do it before you open the box because it was created before APUs existed and it's possible that it just fell into the gap when manufacturers didn't know what to prepare for.
(My opinion is slanted, I think I have a particularly bad example of that board that has been uncooperative since day 1 - but not all are as bad.)
I don't know if there are significantly better mATX boards - AM4 has very few to start with - but you can at least find some with heatsinks.
Nice, apart from that horrible box, 3 boxes from the top.... XDAnother one incoming! Just waiting for case and SSDs to arrive tomorrow. Getting excited!
It's £15 more than mine, and adding in the cost of return postage, it would be a lot cheaper to buy something like the Enzotech MOSFET heatsinks for a tenner:
Certainly worth a go
It's worth mentioning that B450 is out next month. While they do all look like quick refreshes of B350, I'd hope they've acknowledged the existence of APUs now and will have heatsinked those naked mosfets... Just something you could look into if you wanted![]()
Ah, yeah. Gotta get the look right!
Now complete tower of shiny:
Ah.I meant that it was nvidia not an AMD card to go with the rest but turning it around helped also lol
It's the font that got me first, then i saw the green lolAh.
I did think it looked ugly once you mentioned it, though.
I'm quite impressed you could tell it was an nvidia GFX card from that shot, though. I guess the green edging is a bit of a giveaway, but I'd not have been able to pick that if I'd seen that shot...
I've had a look around for reports of people's experiences of this board. I see some people had issues with the CPU VRMs with the high-core count chips and overclocks, but I've seen videos of people using this set-up for gaming and didn't see any reported issues there. Fingers crossed.![]()
To be fair, mine's been fine with a 1600X for 10 months now. Can't overclock it (severe overvoltage if I do, possibly a broken board tbh), but its gaming VRM temps have been around 80-85, which is fine. I know that APUs will work the SoC VRMs much harder, but I guess if it was instant-smoke then the internet would know by now. My guess is that they'll run pretty darn warm, maybe even 100+ degrees and bleed a lot of heat to the caps around them, which will shorten their lifespan somewhat. Putting some heatsinks on those will definitely help![]()
Yay ! building for younvme drive JUST dropped through the letterbox! Must be patient!
EDIT: nvme drive JUST dropped through the letterbox! Must be patient!
Lol, I know the feels, new CPU just arrived and the motherboard isn't until tomorrow, but I still want to start taking things apart ¬_¬ Time is probably better invested in making sure all my bookmarks and save files are backed up, tbh. Builds go SO much faster when they don't start with "Hmm, do I need anything on the drive I'm about to format/discard?"
I still Prime mine because I'm old-school and that's what I'm used to. Once I think it's good I'll leave it running overnight. Cinebench to check that it's running as fast as it should be isn't a bad call.
But it's also designed for heat transfer so... eh. If the drive isn't behind a GPU, it likely doesn't need a heatsink at all.Quick and effective stability testing probably don't go hand in handI still Prime mine because I'm old-school and that's what I'm used to. Once I think it's good I'll leave it running overnight. Cinebench to check that it's running as fast as it should be isn't a bad call.
And just general use for a few days. I've found if mine is not 100% stable it's as likely to randomly bluescreen while I'm drawing in Manga Studio as it is to do so during gaming. (It always turned out to be SoC volts and memory timings.) Touch wood, 20 days without a crash, I think it's good now, at stock and 3000mhz.
If there's a copper sticker on your drive (Samsung?) probably leave it - it will likely invalidate your warranty to peel it because they consider it a heat dissipatorBut it's also designed for heat transfer so... eh. If the drive isn't behind a GPU, it likely doesn't need a heatsink at all.
