- 30 Mar 2010
- Exile
Price sounds about right in today's market. TTs have always seemed to hold value a bit better than a A3 (for example with the same 3.2 engine).
Personally I much prefer the looks of the facelift mk2, but then you're looking at closer to double your budget.
My MK2 TT has been a fantastic car, never intended to keep it long term, but i can see it staying around for many years to come.
Thanks guys, I had also been looking at S3s but haven't seen one that I liked. Just called the guy to get some details, and did an MOT check. This is what it failed on last year.
Fail.
- Supplementary Restraint System warning lamp indicates a fault (5.4.2)
- Nearside Front constant velocity joint gaiter damaged to the extent that it no longer prevents the ingress of dirt etc (2.5.C.1a)
- Nearside Rear Anti-roll bar linkage has excessive play in a ball joint (2.4.G.2)
- Front Brakes imbalanced across an axle (3.7.B.5b)
Advisory
- Nearside Rear Tyre worn close to the legal limit (4.1.E.1)
So imo not worth looking at. I have seen some with spotless MOT records, but they've been too far away. I hate searching for a car!
Was it a 2.0TDI? The 3.0TDI is a great engine
