Thanks for the info I’ll give that Armaf a go see what it’s like. Think it’s about £25 on Amazon. Beats paying nearly £200 for the real thing which I stupidly used to do lolYep, got a tester from ebay a while back and smells the same. They did change Armaf I'm told a while back to try and match the opening smell. Armaf has a lemony smell, whereas creed is pineapple but after it's settled down a bit it totally changes to just like creed. To be honest, I really like the lemon smell personally. I think if you put both on the back of each hand and keep smelling them both you can just about notice a more mellowey smell from creed but if you wore them on their own on back to back days, you wouldnt tell in a blind test. Remember, there are many different batches of creed so it depends on which batch you are testing aganist.
Oh, word of warning about perfume parlour. There creed isn't as close as armaf, and some of their other aftershaves don't last five minutes. I have eight different ones from them and only spice bomb and green tweed last any lenght of time. Also, they tend to be a bit sticky and one of them gave me a rash and sore neck.
