Geforce GTX1180/2080 Speculation thread
22 Nov 2009
Under the hot sun.
Seen this on my Polish forums.
You became famous for the fake picture :D
20 Apr 2004
Oxford
13 Jun 2009
By "120 W card" do they mean the GTX 1170? If so, those prices are bonkers. MSRP up from $380 to $500 in a single generation? People will still eat it up though, sadly.
9 Nov 2009
Planet Earth
Also you mean $249/$299 to $499 - the GTX1060 is a 120W TDP class GPU,so the GTX1060 replacement has doubled in price - apparently. Just look at the die size and salvage level. Now if the 120W TDP class is a salvaged 500MM2+ GPU it might be understandable,but if its well under 400MM2,then its taking the mickey.
Having said that be careful - its Wccftech. Remember,how many times they mentioned the "beast mode" 1600MHZ RX480 cards.
bru
bru
21 Oct 2002
kent
So according to that rumour from wccfTech the new range 11xx series.
The 120w (1060 variant) is going to up in price by 100%.
The 150w (1070 variant) is going up by 33%
The 180w variant is going up by 7%
So a 1160 would cost £460+ and a 1080 would drop to £400
Yes because that seems totally realistic.
Don't believe a word of it, guess work at its best.
TNA
TNA
Caporegime
13 Mar 2008
Greater London
I liked Garak, IMHO one of the best characters in the Star Trek universe.
We really liked Elim also. Not sure about if the best, but he sure was very good.
:D
As usual I don’t buy a word they say either.
19 Dec 2010
My guess, for what it's worth.
The 1180:-
If they do a founders Edition, it will be $749. The normal cards will be $649. Will drop to $549 when the 1180Ti is released.
The 1170:-
Founders Edition: $499, normal edition: $449.
The 1160:-
Top Variant: $349, Lower Variant: $249
The 1080Ti will be $799.
Prices listed come with the usual thing that some of the AIB cards will be cheaper than the prices listed and some will be more expensive.
